POV-Ray : Newsgroups : povray.beta-test.binaries : Function / pattern issues. New inbuilt f_dec_nbit3c, f_enc_nbit3c. : Function / pattern issues. New inbuilt f_dec_nbit3c, f_enc_nbit3c. Server Time
12 Mar 2026 18:30:52 EDT (-0400)
Date: 3 Feb 2021 17:44:30
Message: <601b274e$1@news.povray.org>
<---------------------- References. Sixteen previous posts
Function / pattern issues. Povr surface normal{} like dents.
http://news.povray.org/povray.beta-test.binaries/thread/%3C5f3fb137%241%40news.povray.org%3E/
and
Function / pattern issues. Povr inbuilt status 20 Dec 2020.
http://news.povray.org/povray.beta-test.binaries/thread/%3C5fdfc14f%40news.povray.org%3E/
Elsewhere mentioned I mentioned replacing the .hf, never official,
function block only and undocumented feature in v33.8. For the povr
branch this comes as two new inbuilt functions called f_enc_nbit3c and
f_dec_nbit3c. The 3 c standing for three channels (usually R,G,B) but
the channels can be defined anyway one wants.
I'd also mentioned supporting 2-17 bits of depth per channel, but on
testing realized 1-17 was better because at 1, you can use f_dec_nbit3c
alone as in inbuilt 3 value average pattern function. One which doesn't
need to use the function { pattern/pigment } internal interface.
1-17 bits supports up to 51 bit single value depth (doubles come in at
52). The max in practice will probably be 16 bits per channel as this
will fit in three 16 bit channel image formats of which there are a few.
Using 17 bits requires moving to hdr or exr with float storage. It means
on moving from 16 to 17 bits the storage per value increases from 48
bits to 96 bits.
Why the low bit depths? The depth effectively skews the G and B channels
by powers of 2 and then powers of 2*2. This is useful as one can weight
the contributions and then tune. Further, if the contributions are
functions for example the full bit depth after the power of 2 shifts is
still there when working with/or as is the values have been normalized.
This last a concept the .hf implementation didn't support directly -
users could make it work.
I believe everything here is still doable in v3.8, but it is harder to
code up.
Not experimented too much as yet, but a couple test images attached.
Both using a bit depth of 3, functions for each of the three channel
inputs and marking the inputs normalized. I believe many interesting are
possible.
Credit to whomever wrote .hf. On some level, the approach in povr's two
new inbuilt functions is the same. but one less hardwired to a
particular task.
Bill P.
Download 'f_dec_nbit3c_01.jpg' (248 KB) Download 'f_dec_nbit3c_03.jpg' (409 KB)
Preview of image 'f_dec_nbit3c_01.jpg'
Preview of image 'f_dec_nbit3c_03.jpg'
