POV-Ray : Newsgroups : povray.beta-test.binaries : Function / pattern issues. New inbuilt f_elliptical_sphrswp(). : Function / pattern issues. New inbuilt f_elliptical_sphrswp(). Server Time
13 Nov 2026 00:29:48 EST (-0500)
Date: 13 Jun 2020 15:32:09
Message: <5ee529b9$1@news.povray.org>
<---------------------- References. Twelve previous posts
http://news.povray.org/povray.beta-test.binaries/thread/%3C5ee4b9e3%40news.povray.org%3E/
and
http://news.povray.org/povray.beta-test.binaries/thread/%3C5ee4dc4b%241%40news.povray.org%3E/
To povr adding new f_elliptical_sphrswp(). As Cousin_Ricky has
mentioned, it is not a match for an elliptical torus (supertoroid 1,1
asymmetric a,b), but probably something useful. See attached images.
Of note the implementation is testing out a torus pre-filter - my f_dual
idea to improve isosurface performance. Idea works for performance, but
it introduces a gradient change away from the surface so there are
always max gradient warnings. The actual gradient to use is always
around 1.0 for the sweep itself. So, need to figure out smarter max
gradient determination (near roots); Create a warning on/off option for
isosurfaces(1) - or do both.
(2) - IIRC. Megapov had a warning on/off thingy.
#declare angleStart = 153;
#declare angleArc   = -137;
#declare Iso98 = isosurface {
     function {
         f_elliptical_sphrswp(x,y,z,ax,bz,r,angleStart,angleArc,0)
#declare Pig00 = pigment {
     function {
         f_elliptical_sphrswp(x,y,z,ax,bz,r,angleStart,angleArc,1)
Parameters: x, y, z
Six extra parameter required:
1. The traditional a multiplier of the x axis.
2. The traditional b multiplier of the z axis.
3. The minor radius, r.
4. The starting angle. 0 to 360.
5. The arc angle from the start angle. -360 to 360.
6. 0 = sweep with optimization. 1 = return 0 to 1 map value matched to
angular rotation of arc.  2 = skip up front in torus filter. (e.g. Using
sweep values for map control)
Notes. Like the f_torus() function the f_elliptical_sphrswp() sits
around the y axis at the origin.  In other words, it is sitting in the
x,z plane.  Angles and directional angles are left handed about y.
With respect to isosurfaces; Gradients are decent, but due the internal
method of calculation, performance is somewhat volatile. Larger r values
tend to run more slowly. Rays more orthogonal to the y axis are slower -
sometimes slower than a parametric representation.
The function is close to that of an elliptical torus - supertoroid with
e1,e2 at 1.0 (spherical) and asymmetric x,z axis values.  Also this
method has start and end points - arcs - there is less continuity /
smoothness at the cap spheres than elsewhere in each arc.
Bill P.
Download 'storyellipsphswp.jpg' (63 KB) Download 'storysupertoroidtoesweep.jpg' (35 KB)
Preview of image 'storyellipsphswp.jpg'
Preview of image 'storysupertoroidtoesweep.jpg'
