POV-Ray : Newsgroups : povray.beta-test.binaries : Function/ pattern issues. New pattern_modifiers keyword. : Function/ pattern issues. New pattern_modifiers keyword. Server Time
19 Nov 2026 23:25:42 EST (-0500)
Date: 1 Nov 2019 13:21:09
Message: <5dbc6985$1@news.povray.org>
A new 'pattern_modifiers' keyword continuing work started in the threads:
http://news.povray.org/povray.beta-test.binaries/thread/%3C5da21410%40news.povray.org%3E/
and
http://news.povray.org/povray.beta-test.binaries/thread/%3C5dab3f55%241%40news.povray.org%3E/
We have since v3.5 a vturbulence parse time function. We have too the
existing pattern { } wrapper - though as a function wrapper, especially,
its usefulness is limited. The former handles only turbulence the latter
only returns the resulting pattern value at points in space.
What's missing is a way to access the x,y,z vector result of all the
modifiers a pigment / pattern might employ. So adding: function {
pattern_modifiers {} }. As something function enabled, it's usable at
parse and render time.
The general idea is to set up a real - or dummy - pattern/pigment
defining a collection of modifiers. A collection of warps, turbulence
and transforms. Then pattern_modifier {} grabs just the result of those
operations for a given point returning the function/pattern space
adjusted x,y,z values. The usage is something like:
#declare FnHelix1_5p = function {
     pattern_modifiers { Pigment00 }
#declare FnHelix1_5 = function (x,y,z) {
     FnHelix1_5c(FnHelix1_5p(x,y,z).x,
         FnHelix1_5p(x,y,z).y,
         FnHelix1_5p(x,y,z).z)
for functions. Use in user space requires 'opposite' internal to POV-Ray
values be flipped before use.
See attached example scene and image. The image's left side shows
spheres placed in a vertical column and collected in a union; as well as
a helix1 based isosurface. On the right both the placement of the
spheres and the isosurface are perturbed by the pattern modifiers (here
gentle turbulence and a rotate x*33) both defined with the pigment used
for both final objects.
Bill P.
Download 'pattern_modifiersstory.pov.txt' (5 KB) Download 'pattern_modifiersstory.png' (69 KB)
Preview of image 'pattern_modifiersstory.png'
