POV-Ray : Newsgroups : povray.beta-test.binaries : Fixing longstanding function/pattern issues in v38. New raw_wave keyword. : Re: Fixing longstanding function/pattern issues in v38. New raw_wave keywor= Server Time
28 Mar 2026 19:19:34 EDT (-0400)
Date: 22 Oct 2019 04:57:32
Message: <5daec47c$1@news.povray.org>
On 10/20/19 1:18 PM, Bald Eagle wrote:
> "Bald Eagle" <cre### [at] netscapenet> wrote:
>> Well, I think I found an issue with the way that the angle is calculated for the
>> radial pattern.
> I had it in the back of my mind to mention the effect of phase, but forgot.
> The equations also seem to botch the phase adjustment as well.
> I noticed this when I realized I could probably use phase to rotate the color
> map instead of applying the unmodified pigment to the object and then rotating
> around the origin.
> I _think_ I got to the point where I fixed this as well, but it's all worth a
> thorough double and triple checking.
> FYI.
I think I have a fix in hand. Further that the problem with phase was
rooted in the base radial problem affecting non-integer frequencies.
Internally phase is an adder applied after the frequency multiplication.
See attached. Upper left is your f=360/270 as the new code renders the
breaks in continuity (ramp_wave).
Upper right f=360/270 phase 1/4. Lower left f=4. Lower right f=4 phase 1/4.
Done a fair bit of testing and looking OK to me. It will be a while
before I get a branch out as busy with real life until the middle of
next week. First thought about a branch for just this change, but it's
getting to where I'm carrying too many off master. I'm going to roll
this change into a branch for a set of changes around functions and
patterns I want including this update. I plan opening a more general
github issue covering everything in the set of changes too.
Bill P.
Download 'radialfix_wphase.png' (197 KB)
Preview of image 'radialfix_wphase.png'
