POV-Ray : Newsgroups : povray.animations : BMP to MPEG Server Time
3 Jul 2024 02:32:29 EDT (-0400)
  BMP to MPEG (Message 1 to 9 of 9)
Subject: BMP to MPEG
Date: 19 Sep 2005 12:11:41
Message: <432ee33d$1@news.povray.org>
A common question I'm afraid.
What free software would you recommend to build a series of BMPs into  an
Mpeg?
Subject: Re: BMP to MPEG
Date: 19 Sep 2005 14:01:07
Message: <432efce3$1@news.povray.org>
> Mpeg?
I use http://www.tmpgenc.net/ If you output to PNG instead, use the PNG VFAPI plugin.
Same quality, less
space than BMP.
http://news.povray.org/povray.binaries.utilities/attachment/%3C3a82f26c%40news.povray.org%3E/vfpng.zip
The other common tool used here is http://www.virtualdub.org/
Date: 19 Sep 2005 15:41:23
Message: <432f1463@news.povray.org>
I use AviCreator.
Oleguer
news:432efce3$1@news.povray.org...
>> Mpeg?
> VFAPI plugin.  Same quality, less space than BMP.
Date: 19 Sep 2005 15:42:13
Message: <432f1495@news.povray.org>
Sorry, you were asking about MPEG.
Oleguer
news:432f1463@news.povray.org...
>I use AviCreator.
> Regards,
> Oleguer
>>> an Mpeg?
Date: 20 Sep 2005 02:19:30
Message: <432fa9f2@news.povray.org>
Oleguer Vilella <ole### [at] infonegociocom> wrote:
> I use AviCreator.
  Is that the same AviCreator which I once tried and which, for some
completely inexplicable reason, tried to load *every single image* to
memory before giving the option to save them to an avi (meaning that if
you had even a fair amount of frames you would quickly run out of memory),
and which didn't even have support for codecs?
Date: 21 Sep 2005 16:05:41
Message: <4331bd15@news.povray.org>
Hi Warp,
Well, I don't if it's the same... If the name is AviCreator should be the
same.
It's gives an .AVI archive and you've to render all the images using POV-Ray
to creat the .AVI
Using 30 frames it works OK. I've never used it for more images.
Oleguer
news:432fa9f2@news.povray.org...
>> I use AviCreator.
>                                                          - Warp
Date: 19 Oct 2005 10:55:00
Message: <web.43565d96f2d14f7ff5c315de0@news.povray.org>
> same.
> to creat the .AVI
It is the same, I use Avicreator, only because I haven't found anything
else, its intricacies haven't forced me to find anything else, I can
compile 600 384 x 288 bitmaps with it on my 1700+ Athlon so I haven't had
much troubles, except that you choose the last image in the sequence first
then shift click the first image when opening into Avicreator and it works
ok
James
Date: 26 Oct 2005 14:48:53
Message: <435fcf95$1@news.povray.org>
Ok, I'm happy to help.
Oleguer
news:web.43565d96f2d14f7ff5c315de0@news.povray.org...
>> same.
>> POV-Ray
>> to creat the .AVI
> ok
> James
Date: 15 Nov 2005 02:20:00
Message: <web.43798b83f2d14f7fe45da7f10@news.povray.org>
I didn't ask the question but I'll thank you anyway.
I just came across the need for a PNG -> Video utility and VDub works quite
well. Thanks!
Tom Galvin <tom### [at] impnospamorg> wrote:
> > Mpeg?
> space than BMP.
