POV-Ray : Newsgroups : povray.animations : QT or other problem Server Time
8 Jul 2024 08:27:46 EDT (-0400)
  QT or other problem (Message 1 to 9 of 9)
Subject: QT or other problem
Date: 3 Oct 2003 06:10:02
Message: <web.3f7d4a89882e39d35115eaaa0@news.povray.org>
Hello Friends
 I have been using POV and Quicktime for animation for a long time without
any problems until recently. I am presently experimenting with complex
morphing textures using various normals, finishes and media. I usually do
test renders to Quicktime at 24 FPS, 360 frames, a fairly high rendering
resolution and an image size of 320 x 240. At times I will increase the
image size and re-render when a particular test has been successful and
this is where I've been experiencing problems.
 These larger animations have a random jitteriness(?) when played back. It
almost seems as if some frames of the animation were missing but they're
not. I have given both POV and Quicktime a large dose of memory and
although my computer is not the latest, I've never seen this happen before.
 Any suggestions...please?!
 Thanx in advance
 TGL
Subject: Re: QT or other problem
Date: 3 Oct 2003 09:05:01
Message: <web.3f7d72b1c716b19d10dd5cfd0@news.povray.org>
tgl wrote:
> Hello Friends
> Thanx in advance
> TGL
Well, I'm no computer expert, but I have the same problem when I combine
"fairly high rendering resolution" with "larger animations."  I have an old
Mac G3 that I've souped up a bit, but I think it has difficulty processing
larger images quickly enough to avoid "jitteriness."  If I decrease the
resolution (compress the images more) the problem goes away.  For example,
if I make a quicktime movie with "highest quality jpg" I have trouble, but
if I lower it to "medium quality jpg" the problem disappears.
So it's clearly not a POV animation problem (for me), but rather that I
have an older system trying to do newer things (kind of like my own body
and brain.)
Dave Matthews
Date: 3 Oct 2003 12:25:02
Message: <web.3f7da222c716b19d420d35110@news.povray.org>
tgl wrote:
> Hello Friends
> Thanx in advance
> TGL
The best you can do is render the frames in POV at the same size as the
intended animation.
Letting animation software reduce the size of the frames is a lossy process
and is causing the artifacts you describe.
Eddie
Date: 3 Oct 2003 13:27:43
Message: <3f7db18f@news.povray.org>
In article <web.3f7da222c716b19d420d35110@news.povray.org> , "POVeddie"
>> Thanx in advance
>> TGL
> intended animation.
I don't think you even remotely understood the question ...
Excuse me, are you on drugs?
    Thorsten
Date: 3 Oct 2003 13:38:06
Message: <3f7db3fe$1@news.povray.org>
In article <web.3f7d4a89882e39d35115eaaa0@news.povray.org> , "tgl"
> not.
The frames are "dropped" when playing back the movie because you system
isn't fast enough to decode all the frames in real-time.  This can either be
due to processor decoding performance or harddisk data-rate limitations.
Either way, the only way around this (other than getting a faster system) is
to use a different codec.  If you have G3 at 500 MHz or more, you can for
example get one of the free MPEG-2 encoders (encode to VOB!) and then use
the DVD Player (or QuickTime with the MPEG-2 plugin from Apple) to play it
back - it will use the accelerated decoding functions on your graphics card
and that way you should be able to view movies up to 720*576 at 25 fps or
720*480 at 30 fps, which equal PAL and NTSC DVDs respectively.
If you have a Mac much older than three years, you will more or less have to
stick to lower resolutions or reduce the framerate...
    Thorsten
e-mail: tho### [at] trfde
Date: 3 Oct 2003 20:50:02
Message: <web.3f7e1894c716b19d1b238cd0@news.povray.org>
>and brain.)
>I really didn't want to face the fact but I'm in the exact same predicament as you
are. I have a G3(B+W) as well. I guess there are some limitations I gotta deal with.
Damn!;)
 Thanks a lot for your response Dave.
Date: 3 Oct 2003 22:35:01
Message: <web.3f7e3125c716b19d4a8b8d420@news.povray.org>
Thorsten Froehlich wrote:
>In article <web.3f7d4a89882e39d35115eaaa0[at]news.povray.org> , "tgl"
>> not.
 Thanx for the info, Thorsten but I believe I'm stuck with your final
suggestion!
By the way...How the heck did you and Dave Matthews know I was a MacUser?
Date: 3 Oct 2003 23:09:06
Message: <3F7E39FA.E6958B53@pacbell.net>
Elementary, my dear Watson.
Most Windows users don't like or just plain won't use QT for various reasons
and it is not available on the linux/unix platforms. If you have been using
QT for sometime, as suggested in your original post, it follows that you are
a Mac user.
Ken Tyler
Date: 4 Oct 2003 03:58:47
Message: <3f7e7db7@news.povray.org>
In article <3F7E39FA.E6958B53@pacbell.net> , Ken <tyl### [at] pacbellnet>
> a Mac user.
No, it is much simpler than that: Windows PCs don't last more than three
years ;-)
    Thorsten
