POV-Ray : Newsgroups : moray.win : Moray 3.5 and Pov-ray 3.5 both run on Windows 11 Server Time
16 Jan 2026 19:22:03 EST (-0500)
  Moray 3.5 and Pov-ray 3.5 both run on Windows 11 (Message 12 to 21 of 41)
Subject: Re: Moray 3.5 and Pov-ray 3.5 both run on Windows 11
Date: 27 May 2023 14:30:00
Message: <web.64724ab4cfce83799b4924336e066e29@news.povray.org>
> I have your answer about "exporting" to POV-Ray. Just click on the
> "Raytrace" button or F9. If the communication between Moray and POV-Ray
> v3.5 works correctly, this generates a POV scene file which then renders
> the image in POV-Ray. The scene file can of course be saved as a .pov scene.
> Even if everything seems to fail - as in my case (but see: *) - the test
> scene I had built in Moray was translated to POV-Ray code and stored in
> its "POVscn" folder.
> * While writing this I just got the whole thing to work! :-)
> Just a matter of correctly defining the folder destinations in Moray:
> use Alt+F9 or click the "Render Options" button
Yes, I see that Alt-F9 brings up the 'Render options' window. I didn't know
about that.
But I'm still having no luck exporting. *However*, I have not yet installed
POV-ray v3.5. (just v3.8.0 beta 1).
It appears that I am doing exactly what you suggest, but no luck. In Moray's
'Render' menu, I have tried both F9 and Ctrl-F9, but nothing happens and no SDL
file shows up in the "POVscn' folder.
I do understand that Moray only works 'in tandem' with v3.5 for *rendering*, so
I was not expecting an actual render to occur; but I was hoping that I could at
least export the scene as SDL, somehow.
My current trials are like this:
I open one of Moray's included .mdl demo scenes, like 'Swan' (I've also tried
'Coffeecup'.) Then, without changing anything in the scene or menus, I try
exporting with F9 or Ctrl-F9. Nothing. :-(  Of course, F9 is a RENDER button, so
I was not surprised by the error message that showed up, "Cannot start POV-ray.
Please start POV-ray manually and try again."
(BTW, in the 'Render options' window, I tried un-checking the 'Active Renderer'
box-- but it refuses to be un-checked. As if that has any meaning for the
problem!)
I am going to download POV v3.5, if it is still available on Github. I have the
suspicion that it is required, even for the export of a file. Otherwise, I have
no clue as to why the export feature is not working.
Download 'moray_trial_in_windows_10.jpg' (270 KB)
Preview of image 'moray_trial_in_windows_10.jpg'
Date: 28 May 2023 11:05:36
Message: <64736dc0$1@news.povray.org>
Op 27-5-2023 om 20:26 schreef Kenneth:
> about that.
It seems that the /special/ DLL provided by Moray to communicate with
POV-Ray, only works with version 3.5. When you have installed POV-Ray
v3.5 you can see at the top "GUI-Extensions" and within "Moray
Communications DLL" which is probably installed there I guess, the first
time you link both apps. Somehow, Moray is unable to link that DLL with
a more recent version of POV-Ray.
It may be worthwhile to check the directory paths shown in the "Render
Options" and maybe adapt those to your particular wishes...
I thought so too...
In my case, POV-Ray v3.5 just freezes, and I have to crash-close it...
> problem!)
I am able to uncheck it but I don't know what is its use...
In any case, in most instances, either POV-Ray freezes, Moray cannot
make contact, or nothing happens. In rare cases, a miracle occurs and a
render is performed, typically with Moray files younger than about 2000.
When a render occurs, I am unable to repeat a second render. In any
case, I am unable to render any scene in POV-Ray v3.5 so there is much
not working as it should (Windows problems with older apps?)
I am curious to learn your experiences.
Date: 28 May 2023 11:45:00
Message: <web.647375cdcfce83799b4924336e066e29@news.povray.org>
Well, apparently it is no longer available for download there?? v3.7.0.0 is the
earliest version available. Unless I am looking in the wrong place...
https://github.com/POV-Ray/povray/releases
> > [Thomas wrote:]
> > Just a matter of correctly defining the folder destinations in Moray...
Here's something interesting: As an experiment, I changed Moray's default
library path for finding the POV-ray pvengine.exe file-- to my v3.7.0 install,
and also to v3.8.0 beta 1. (I chose the 32-bit versions of each in the POV 'bin'
folder).
Then in Moray's 'Render' menu, when I press either 'Raytrace' (F9) or 'Render',
POV-ray automatically starts up! But nothing is actually rendered, as expected--
Moray's render-image pane is black; nor does the Moray scene show up in POV-ray
as SDL.
It was worth a try though, just to see what would happen.
Date: 28 May 2023 12:15:00
Message: <web.64737dddcfce83799b4924336e066e29@news.povray.org>
 Aha! That's very interesting, and probably the most important clue to the
problem I'm having. Thanks for the info!
From my own tests with the changed library path, I was genuinely surprised that
Moray could even fire up POV-ray v3.7/3.8 automatically. So it does seem that
Moray is *trying* to make the 'tandem' connection with it...but something goes
wrong during the process.
Meanwhile, I hope I can find POV-ray v3.5 available somewhere...
Date: 28 May 2023 12:40:00
Message: <web.64738395cfce8379b49d80446cde94f1@news.povray.org>
hi,
if you can find someone to build it for you/your Windows machine, I have the
3.50c source to hand.
regards, jr.
Date: 28 May 2023 18:30:00
Message: <web.6473d56ccfce83791f9dae3025979125@news.povray.org>
I'm guessing that since it was a sort of home-brew app, then maybe there's a lot
of stuff like filenames hard-coded into the Moray source.
Is there a way to run a decompiler or some other analysis software to see what
filename Moray is trying to find/execute?
I'm guessing that Moray somehow needs the editor to make the SDL file, and
that's why POV-Ray needs to be installed.
Perhaps fill a directory with all known POV-Ray editor and engine filename
permutations and see which one got accessed?
Maybe a later version can be renamed and placed into a 3.5 directory to see what
happens?
Just shooting in the dark here.
Date: 29 May 2023 02:10:02
Message: <647441ba@news.povray.org>
Op 28/05/2023 om 18:14 schreef Kenneth:
It is available at the POV-Ray site itself:
https://www.povray.org/ftp/pub/povray/Old-Versions/Official-3.5/Windows/
Date: 29 May 2023 02:14:15
Message: <647442b7$1@news.povray.org>
Op 28/05/2023 om 17:39 schreef Kenneth:
It is available at the official POV-Ray site:
> folder).
> as SDL.
Yes, I had the same happen to me indeed.
Date: 29 May 2023 10:25:00
Message: <web.6474b501cfce83799b4924336e066e29@news.povray.org>
Great! Many thanks. Just out of curiosity, is there an obvious or official link
to that page, somewhere in the newsgroups?
I wonder if there are even earlier versions available, tucked away in some
equally obscure(?) location.
[JR wrote:]
> the 3.50c source to hand.
Thanks for the offer. Personally, I know next to nothing about compiling a
program for Windows. Or even what kind of older(?) tools and tricks that might
be required for compiling such 'ancient' v3.50 source code, ha.
Date: 29 May 2023 10:43:30
Message: <6474ba12$1@news.povray.org>
Op 29-5-2023 om 16:21 schreef Kenneth:
Yes. Go to the official site: https://www.povray.org/download/
Scroll to the bottom of the page where you will find "Old Versions of
POV-Ray". They tell us that all official releases since version 1.0 can
be found there (old version tree).
