POV-Ray : Newsgroups : moray.win : How do I rotate a citygen 1.5 scene in moray? Server Time
2 Apr 2026 13:54:00 EDT (-0400)
  How do I rotate a citygen 1.5 scene in moray? (Message 1 to 7 of 7)
Subject: How do I rotate a citygen 1.5 scene in moray?
Date: 28 Jan 2007 01:35:00
Message: <web.45bc43458f47c8365604e8e60@news.povray.org>
I want to use a scene create with CityGen v1.5
(http://members.tripod.com/~dcieslak/util.html) in moray. I find I can
easily bring in the scene and have it rendered. But of course the city is Y
up and moray is z up. what is the best way to rotate the city? I tried using
the POVInclude plugin for Moray
(http://www.kolban.com/3d/POVInclude.htm) with the option "inclusion of
POV-Ray to Moray coordinate system transforms." checked but had no luck.
Any assistance would be welcomed. Thank you.
Subject: Re: How do I rotate a citygen 1.5 scene in moray?
Date: 28 Jan 2007 03:06:51
Message: <45bc599b$1@news.povray.org>
"JReyes" <nomail@nomail> schreef in bericht
news:web.45bc43458f47c8365604e8e60@news.povray.org...
> Y
> using
Basically, the transform from POV-Ray to Moray (or from Moray to POV-Ray) is
very simple. The only thing you have to do is to add two commands to the (I
suppose) union englobing your city:
scale <1, 1, -1>
rotate <90, 0, 0>
That's all.
When using the POVInclude plugin, the advanced option you mention is only
used for the placeholder box visible in Moray and containing the POV-Ray
object. There is a pdf tutorial available for this plugin. If you are
interested, I can post it in moray.binaries.
Date: 29 Jan 2007 00:15:00
Message: <web.45bd81e78031825d3fcc65ba0@news.povray.org>
> scale <1, 1, -1>
> rotate <90, 0, 0>
> That's all.
> Thomas
I'm not great with povray script writing and I think that is where my
problem is. I don't know how to declare the whole city as one object and
rotate it. I'm going to download files from povray.text.tutorials and see
if I find one with an example that I can copy-paste and edit to do this.
thank you for such a quick response!
Date: 29 Jan 2007 03:06:30
Message: <45bdab06@news.povray.org>
news:web.45bd81e78031825d3fcc65ba0@news.povray.org...
Well, to be frank, I was not aware of CityGen itself, so I downloaded it. I
shall try it to see how the file looks like.
Date: 29 Jan 2007 04:12:38
Message: <45bdba86$1@news.povray.org>
OK. I have rapidly tested CityGen. Here are some thoughts:
- Most important: CityGen is an OLD program (1999) and it exports to POV-Ray
3.0. That generates some troubles, especially missing semi-colons after all
declarations etc. but easy to overcome: run you scene a number of times in
POV-Ray and read the error messages appearing. When your scene renders
correctly, your SDL will be ready for Moray.
- Now, for your specific problem, you have to do the following as CityGen
does not group the streets and buildings into separate entities:
--> Go to the line labelled "City Scene"
--> Above that line type:  union {
--> Go to the end of the file and type the following three lines:
scale <1, 1, -1>
rotate <-90, 0, 0>
-->if you use the Moray camera and lights, you have also to comment out the
whole header part of the CityGen scene, i.e. the part of the script between
"Standard Camera" and "End of Header".
Hope this helps.
Date: 30 Jan 2007 10:50:01
Message: <web.45bf679f8031825d2e8e680f0@news.povray.org>
> scale <1, 1, -1>
> rotate <-90, 0, 0>
> Hope this helps.
> Thomas
Awesome! It works great. I also used union on the lights and planes created
by Citygen and rotated those.  Except for an error with the fog it also
worked. I decided using Moray's built in fog in scene settings gave better
results anyway so I deleted the fog created by Citygen. I didn't seem to
need to use "scale <1, 1, -1>" at the moment because the size seems right
on. I imagine that I'll need to modify in the future when mixing with other
objects and or effects in Moray. The "rotate <-90, 0, 0>" had to be changed
to "rotate <90, 0, 0>".
Thomas I saw your name on the GEOMORPH macro for creating isosurfaces. I
haven't learned to use it yet but hope to create a good landscape for
cities created by citygen with its functions. I do wish that citygen did
support the current povray SDL. I like the Moray city plugin but citygen's
quick street and building setup are features I really like. That's what
keeps me coming back to it. Plus there is something appealing about those
simple box buildings.
   I don't know anything about using isosurfaces but is it possible for your
macro to be made into a Moray plugin like keith HullsChris Colefax's city
plugin?
Well thanks again.
Date: 31 Jan 2007 03:50:03
Message: <45c0583b$1@news.povray.org>
news:web.45bf679f8031825d2e8e680f0@news.povray.org...
> created
> other
> changed
Yes, fog may react strangely. Better to stick to Moray there.
Without the scale command, your city will be mirrored. That is not
immediately obvious perhaps. Without the scale, rotation becomes positive
too.
Ah, yes, my Geomorph macro!! That grew somewhat out of hand :-)
Very useful, but start simple. Also, be aware that isosurfaces take much
more time to render than height_fields.
If you want to dive into isosurfaces, be sure to visit Mike Williams' site:
http://www.econym.demon.co.uk/isotut/ before using Geomorph. It will give
you a feeling of the thing. There was another tutorial by Samuel Benge, but
that site seems to have disappeared...
> your
> plugin?
It probably is possible, but way beyond my skills I am afraid... The best
way to do that would be through FullMoon 2, I think. But then, still, you
would have a problem showing the isosurface in Moray, except for a
placeholder.
> Well thanks again.
You are welcome :-)
