"Randy" <wro### [at] charternet> wrote:
> Here is the software I am currently using
> PovRay V3.6
> Moray V3.5 Build 9930
> Animation Plugin V1.31(bete22)
> The DOCs for Amiamtion Plugin indicates that it supports Key Framing for
> some texture manipulations. More specifically, changes in RGBFT.
> Here's the situation: I have an object with a texture applied. I Key
> Frame this at one point and then at another point I change the filter and
> transmit for the material and set the key frame. However this does not
> change these values over time as I would expect, but rather it changes the
> applied material for the object completely, even at and before the first
> key frame.
> WHAT AM I MISSING!!! or is this a bug?
> Any help with this feature would be appreciated.
> Thanks
Got the same Problem: Did you find the clue yet? Or is there a way to export
the individual Pov - codes of the animation frame for manual manipulation?
Mike
