its a problem withe the animation-Povray dll. have a look whether the
moray-animation plugin shows up in the pov-plugins. if it doesn't please
reread the instructions for installing the animation plugin . I don't
recall whats the problem but this should help you.
Arne
jens wrote:
> Mark McGahee <env### [at] examplenet> wrote:
>>jens wrote:
>>>I use Moray 3.5 build 9330 and POV 3.6 under WinXP SP1.
>>Pov 3.6 and Moray 3.5 don't get along so well. Try using Pov 3.5 instead.
> I did indeed downgrade from POV 3.6.1 (not 3.6 as previously reported) to
> 3.5.
> But the same effect still persists: only the first frame gets rendered by
> POV, while all other renderers from the animation options menu render the
> full film.
> I also tried to choose different output formats. Made no difference.
> It seems to me that MORAY does not recognize that POV has finished the frame
> and waits and waits. POV displays the freshly rendered image but the *.avi
> window of MORAY remains black. In the animation options menu of MORAY the
> job is still active and inside POV the communications DLL sais it is
> connected to MORAY.
> So everything looks perfect. But it still does not continue rendering.
> I am running out of ideas.
> Is there anyone who happens to know how MORAY is supposed to recognize a
> finished frame?
> Thanks
> Jens
