Hi. I <em>always</em> get this error message when I try to render anything
that uses a mesh:
texture { BumpMetal <----ERROR
Parse Error: No matching } in 'texture', material identifier found instead
Returned from renderer with error status
Question: Is there something obvious I am overlooking when it comes to
using meshes?? Thanks in advance.
=Greyfang=
Subject: Re: Always get texture error when assigning any texture to a mesh object...
Date: 1 Aug 2004 13:54:21
Message: <410d2e4d$1@news.povray.org>
web.410b062787151c5a9de60ad10@news.povray.org...
anything
> that uses a mesh:>> texture { BumpMetal <----ERROR>> Parse Error: No matching } in 'texture', material identifier found instead>>> Returned from renderer with error status>>> Question: Is there something obvious I am overlooking when it comes to> using meshes?? Thanks in advance.>> =Greyfang=>>
For meshs you must tell moray to export a texture and not a material
You can do that in the material editor
select the material you want do do a texture of
right click on it click on "Porperties/Rename"
check the box "This is a mesh2 texture......"
done
Marc
"Marc Jacquier" <nos### [at] wanadoofr> wrote:
> web.410b062787151c5a9de60ad10@news.povray.org...> > Hi. I <em>always</em> get this error message when I try to render> anything> > that uses a mesh:> >> > texture { BumpMetal <----ERROR> >> > Parse Error: No matching } in 'texture', material identifier found instead> >> >> > Returned from renderer with error status> >> >> > Question: Is there something obvious I am overlooking when it comes to> > using meshes?? Thanks in advance.> >> > =Greyfang=> >> >> For meshs you must tell moray to export a texture and not a material> You can do that in the material editor> select the material you want do do a texture of> right click on it click on "Porperties/Rename"> check the box "This is a mesh2 texture......">> done>>> Marc
THANKS!
Date: 5 Aug 2004 06:58:47
Message: <411212e7@news.povray.org>
