POV-Ray : Newsgroups : moray.win : multiple textures? Server Time
26 Jun 2024 05:27:25 EDT (-0400)
  multiple textures? (Message 1 to 10 of 12)
Subject: multiple textures?
Date: 4 Nov 2003 17:20:01
Message: <web.3fa824d45cc7fbb1640044d0@news.povray.org>
Hi!
First let me say that I'm pretty new to this stuff, and I hope this is the
right group to post to. I have looked through the docs and browsed this
newsgroup server, but haven't really found an answer, so pardon me if I
missed it and this has been covered already.
What I'm trying to do is texturing a basically boxed shaped object (it's
made from a trans sweep, but that shouldn't matter) with an imagemap. Did I
miss something or is it not possible to have some kind of cube mapping so
that each side of the object gets properly textured (hope you know what I
mean)?
Is it possible (in POV in general and in Moray in particular) to put
different imagemap textures on the individual sides if a, for example,
cube?
Again, I'm pretty new to this stuff, so please be easy on me :)
Thanks, Nils
Subject: Re: multiple textures?
Date: 4 Nov 2003 19:10:31
Message: <3fa83ff7@news.povray.org>
> cube?
Absolutely.
^_^
Date: 4 Nov 2003 19:32:36
Message: <ovggqvsnsq7ussrt9t6t0p71aj602mcreh@4ax.com>
On Tue, 04 Nov 2003 19:11:01 -0500, Tim Cook <z99### [at] bellsouthnet> wrote:
>> cube?
>Absolutely.
>^_^
Come on Tim.
Yes it is possible but not easily. The image map needs to be made with something
like UVmapper and you need a spherical maping. Another way is using Ver 3.5 is
to convert it into a mesh then UV map individual faces or groups with seperate
imagemap textures.
Regards
Date: 4 Nov 2003 20:16:49
Message: <3fa84f81@news.povray.org>
At http://www.povray.org/documentation/view/191/
see the section 6.7.7.1, "Supported Objects", specially "box".
Date: 4 Nov 2003 22:10:01
Message: <web.3fa8692fbbbde712d68ed1650@news.povray.org>
thanks.
I've been fiddling around a bit with this mesh stuff (told you I'm VERY new
to this), but while editing meshes works fine for me I can't really figure
out how to actually texture and UV map selected faces. Povray gives me an
error anytime I invole some kind of material. Can you point me to any
tutorials about the steps neccessary to texture a mesh?
Date: 5 Nov 2003 04:38:22
Message: <3fa8c50e$1@news.povray.org>
web.3fa8692fbbbde712d68ed1650@news.povray.org...
> thanks.
new
> to this)
Welcome Aboard :c)
Everybody is new to everything at the beginning.
>. Povray gives me an  error anytime I invole some kind of material. Can you
point me to any
Yes, for a mesh, you have to make a mesh texture.
In Moray,
open the material editor,
select the material that is causing an error
right click
select Properties/Rename   (shortcut Alt/Enter)
Check "This is a mesh2 texture...." box
Doesn't it work better?
Moray doesn't allow a material on a mesh, only a texture ( material is a
hierarchy level above a texture:
material{texture{...}[interior{...}]}
in pov language, interior being optional.
By default, Moray exports materials to POV even if you put no interior so
you have to tell Moray to export only a texture.
Marc
Date: 5 Nov 2003 07:13:00
Message: <2aqhqv40si7pss4bdi90f0uscjr070bgom@4ax.com>
On Tue,  4 Nov 2003 22:06:23 EST, "hoven" <hov### [at] gmxnet> wrote:
>thanks.
Marc has told you how to create a mesh texture. What I did is create a normal
texture with an image map and apply it to a box. Made sure the scaling was
correct (Scale <2,2,1> Translate <-1,-1,1>). The rendered image looks like a
solid picture on two faces of the box. (I hope you are following my inexact
method, I don't have a working system at the moment and this is all from
memory.)
Copy this material and past it as a top layer Ctrl + E
Change it to a mesh texture.
Do this five more times and change the image in the image map
Convert the box to a mesh.
Select the mesh and add the six mesh textures. In the Edit Tab (I'm getting a
bit hazy here) select one face. Further down you can select the mesh texture you
want for that face then set it (Set to Mat, Don't forget this). Do the same for
the other sides. You will need to adjust the rotation and translation.
Regards
Date: 5 Nov 2003 07:31:30
Message: <ncrhqvssif27bmsjcp7sh9kpi5ibs1tkvc@4ax.com>
On Wed, 05 Nov 2003 12:12:56 +0000, Stephen McAvoy <McA### [at] aolcom> wrote:
Sorry, that is the rotation and translation of the Image Map. This is because
the image will be in the XY plane and you will want some in the XZ and YZ
planes.
Regards
Date: 5 Nov 2003 08:09:53
Message: <3fa8f6a1@news.povray.org>
  Try using uv_mapping.
Date: 5 Nov 2003 09:07:10
Message: <201iqvgv3r9g82jnaqd89p4ok7c7gfq32o@4ax.com>
Yes a good idea but I can't say anything about it just now. No graphics
programmes on my m/c till I reinstall them. Do you have a tutorial for Hoven?
Regards
