I am playing around with Photons. In the Modify Tab in the Photon
section, there is a Numeric Box to the right of the Target check box.
What is it for?
Regards
pvu4n0h853ohhiocssvqmmp3anavvn339c@4ax.com...
> What is it for?
For the spacing_multiplier
The density of the photons can be adjusted by specifying the
spacing_multiplier.
If, for example, you specify a spacing_multiplier of 0.5, then the spacing
for photons hitting this object will be 1/2 of the distance of the spacing
for other objects.
Marc
On Sun, 17 Oct 2004 17:23:02 +0200, "Marc Jacquier"
>spacing_multiplier.
>for other objects.
>Marc
Thanks Marc. I was trying in the other direction e.g. 2, 4, 10 etc.
Regards
8o35n09eqdd6o7pu4in41k23b03c44t4nh@4ax.com...
> Regards
> Stephen
Oh it's just a copy/paste from the POVdoc ;-)
Marc
On Sun, 17 Oct 2004 18:07:00 +0200, "Marc Jacquier"
>Marc
Duh! It's not labelled. There's the rub.
That's one problem with the Moray docs IMO. Tying them up to the Pov
docs.
Regards
