POV-Ray : Newsgroups : moray.win : Moray Material Librarys Server Time
17 Jan 2026 12:49:00 EST (-0500)
  Moray Material Librarys (Message 1 to 4 of 4)
Subject: Moray Material Librarys
Date: 16 Aug 2000 12:59:43
Message: <MPG.140475ff55346248989683@news.stmuc.com>
Hey there,
	I recently had to reinstall Moray after erroneously removing it
during a spate of disk cleaning.  Now I can no longer load the prebuilt
texture libraries into Moray (using version 3.2 build 5298).  I have
tired renaming the texture library and reseting the search directory then
restarting Moray, to no avail.  I've tried creating a new directory under
Moray for Windows and moving the texture libraries there, but still no
good.  Any ideas on how I may fix this?
Subject: Re: Moray Material Librarys
Date: 16 Aug 2000 19:28:02
Message: <1o8mpsgvmfroemre82qqeh275s6ilfa2lh@4ax.com>
Hi Ken Stager, you recently wrote in moray.win:
Yes, this is a known bug when the Texture Library is moved, or Moray
re-installed. There is a fix, but it involves editing the Registry, so
you should only attempt it if you know what you are doing.
Exit Moray.
Open RegEdit.
Navigate to HKEY_CURRENT_USER\Software\SoftTronics\Moray For
Windows\Config
Select the key called 'TextureLibraryPath'
Delete it.
Close RegEdit.
Moray should now find the libs when you restart it.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 16 Aug 2000 19:41:01
Message: <MPG.1404d40b776a9512989684@news.stmuc.com>
Thanks Lutz, that worked.  So you are implying that other folks can't be
trusted to edit the Registry? :-)
> Exit Moray.
> Open RegEdit.
> Windows\Config
> Delete it.
> Close RegEdit.
> - Lutz
Date: 17 Aug 2000 03:09:24
Message: <qr3npsguetseflhnvfaalkidogk08340ij@4ax.com>
I myself have never understood the hysteria surrounding editing the
Registry, since RegEdit is a pretty straightforward tool and if you
don't go removing stuff you're not sure about there really shouldn't
be a problem.
It's just a disclaimer<g>.
- Lutz
