POV-Ray : Newsgroups : moray.win : Feature request - bounding boxes Server Time
16 Jan 2026 19:12:13 EST (-0500)
  Feature request - bounding boxes (Message 1 to 3 of 3)
Subject: Feature request - bounding boxes
Date: 3 Feb 2004 05:10:13
Message: <6rsu10l0ov7gmqv00q7g4htcs12tqeslgn@4ax.com>
After playing with bounding boxes for a bit, I think it would be useful to be
able to manually select and set the bounding box. Take the case of two spheres
intersecting to create a lens shape. When you create a bounding box it describes
the union of the spheres.
I assume that this is by design so manually adjusting it would be nice.
Regards
Subject: Re: Feature request - bounding boxes
Date: 4 Feb 2004 00:45:40
Message: <mk1120tnqk0d126f5fp1f8bh7j1hggcrgj@4ax.com>
Hi Stephen McAvoy <mcavoys[at]aolDOTcom>, you recently wrote in
moray.win:
OK, maybe I don't understand, but you want something different than
what you get when you press Alt-B or select Scene|Select Bound with
the object selected? If so, how would it be different?
When you have the bounding box selected you use normal object
transformation methods to manipulate it....
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 4 Feb 2004 05:19:11
Message: <ljh120drp6a4ddtjhqvftikp671unke0fc@4ax.com>
On Tue, 03 Feb 2004 21:45:46 -0800, Lutz Kretzschmar <lut### [at] stmuccom> wrote:
>the object selected
Now, that's the nicest RTFM so far:-}
I did not .notice MID_SELECT_BOUND in CommandList.txt nor Scene > Select Bound.
Using Alt-B the bounding  box is coloured yellow and the transformations are
visible. On the other hand, the way I tried it was to manually select the
bounding box when it is coloured Reddish. Then is no transformation box shown.
Build 9330, Win XP
Regards
