After playing with bounding boxes for a bit, I think it would be useful to be
able to manually select and set the bounding box. Take the case of two spheres
intersecting to create a lens shape. When you create a bounding box it describes
the union of the spheres.
I assume that this is by design so manually adjusting it would be nice.
Regards
Hi Stephen McAvoy <mcavoys[at]aolDOTcom>, you recently wrote in
moray.win:
OK, maybe I don't understand, but you want something different than
what you get when you press Alt-B or select Scene|Select Bound with
the object selected? If so, how would it be different?
When you have the bounding box selected you use normal object
transformation methods to manipulate it....
- Lutz
email : lut### [at] stmuccom
Web : http://www.stmuc.com/moray
On Tue, 03 Feb 2004 21:45:46 -0800, Lutz Kretzschmar <lut### [at] stmuccom> wrote:
>the object selected
Now, that's the nicest RTFM so far:-}
I did not .notice MID_SELECT_BOUND in CommandList.txt nor Scene > Select Bound.
Using Alt-B the bounding box is coloured yellow and the transformations are
visible. On the other hand, the way I tried it was to manually select the
bounding box when it is coloured Reddish. Then is no transformation box shown.
Build 9330, Win XP
Regards
