POV-Ray : Newsgroups : moray.win : 3DWIN Server Time
18 Jan 2026 17:10:00 EST (-0500)
  3DWIN (Message 1 to 2 of 2)
Subject: 3DWIN
Date: 4 Jun 1998 10:39:05
Message: <6l67pb$e1a$1@oz.aussie.org>
I am experiencing problems.. I am using Spatch and exporting it to DXF
format and trying to use 3DWin w/Moray for win to import it to Pov 3/UDO..
it imports but wont trip the Export button to output to UDO for me??  anyone
else having this problem?  I tried running it externally and as a plugin in
Moray both with the same result.. Lutz you got your ears on on this one?
Subject: Re: 3DWIN
Date: 4 Jun 1998 11:28:27
Message: <3576bcb6.26357329@194.174.214.10>
Hi John N. Miller, you recently wrote in moray.win:
Any reason why you're not using the direct sPatch-to-Moray filter? Get
it from http://www.stmuc.com/moray.
3DWin can only export if it has read in triangles, i.e. if the vertex
and face count are non-zero after importing. If this is not the case
then the DXF probably doesn't contain any 3DFACE entities.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
