SimCloth1a.zip now available for download linked from
http://ca.geocities.com/morayplugin
Developed using
Moray 3.5 build 9330
MegaPov 1.0
Fullmoon 1.1b
A plugin to help with creating a cloth file (.cth), and passing on
parameters to the simcloth{} object.
'Sample scene pictures' link is slow, many pictures :-)
It's still easy to confuse the plugin. Not much error checking done.
Comments welcome.
Subject: Re: SimCloth.lua plugin (Cloth simulation of MegaPov)
Date: 19 Oct 2004 02:59:21
Message: <4174bb49$1@news.povray.org>
"StephenS" <sshonfield(at)ottawa(dot)net> a écrit dans le message de news:
4174853a$1@news.povray.org...
Hey! cool but...
downloaded and unzipped SimCloth1a.zip and Helper1a1.zip in Moray plugin
directory
I get an "error in CLS_lua_new (class.c at 108): unknown class name"
Marc
Date: 19 Oct 2004 05:49:39
Message: <4174e333$1@news.povray.org>
Thanks.
But similar, like Marc Jacquier
Friendly
Sylvain
news:4174853a$1@news.povray.org...
> Developed using
> MegaPov 1.0
> Fullmoon 1.1b
> Comments welcome.
> Stephen
Date: 19 Oct 2004 05:52:30
Message: <4174e3de@news.povray.org>
> Hey! cool but...
> directory
> Marc
Oops.....
Comment out line 10 of SimCloth.lua
Change from:
self.mesh=new("test")
to
--self.mesh=new("test")
Or remove the line alltogether.
See if that helps.
Will put a new zip file together when i get some time.
Date: 19 Oct 2004 06:09:32
Message: <4174e7dc$1@news.povray.org>
> Oops.....
> Change from:
> to
> See if that helps.
> Stephen
Thanks again
That's working
Friendly
Sylvain
Date: 19 Oct 2004 07:58:20
Message: <4175015c$1@news.povray.org>
"leseur sylvain" <syl### [at] potar-hurlant com> a écrit dans le message de
news: 4174e7dc$1@news.povray.org...
> Thanks again
> That's working
> Friendly
> Sylvain
Same here :D
Victoria's getting to get a burka ;-)
Marc
Date: 19 Oct 2004 09:18:24
Message: <41751420@news.povray.org>
Setting version to megapov 1.1 still outputs a : #version unofficial megapov
1.0;
Marc
Date: 20 Oct 2004 17:01:52
Message: <4176d240@news.povray.org>
megapov
> 1.0;
> Marc
The sample scenes provided, has the #version coded in the
Scene Settings/Includes
Remove these lines
#version unofficial megapov 1.0;
The plugin should be outputting the correct #version.
Will fix with next update.
Date: 21 Oct 2004 02:16:44
Message: <4177544c@news.povray.org>
4176d240@news.povray.org...
> Remove these lines
> Stephen
Oh I didn't look there, thanks
Excellent job anyway :)
Still testing..
Marc
Date: 21 Oct 2004 08:00:10
Message: <4177a4ca@news.povray.org>
Great ! But not easy and slow....
Is it possible to get a rounded nappe ?
Friendly
Sylvain
> Developed using
> MegaPov 1.0
> Fullmoon 1.1b
> Comments welcome.
> Stephen
Date: 21 Oct 2004 21:15:01
Message: <41785f15$1@news.povray.org>
> Friendly
> Sylvain
The simcloth{} object will only accept a rectangular grid (N1xN2).
You can fake a round nappe by having the texture with transparent parts.
See picture in moray.binaries
simcloth_round_nappe
The current plugin will not let you have more than one plugin.
'can not re-declare a function'
Will be fixed in next update.
Date: 22 Oct 2004 03:58:40
Message: <4178bdb0$1@news.povray.org>
Thanks Stephen.
Friendly
Sylvain
news:41785f15$1@news.povray.org...
> > Friendly
> > Sylvain
> Stephen
> > Friendly
> > Sylvain
> Stephen
Hi Stephen,
Could you provide more info about the error message? Maybe I can help you
correct the bug.
I took a look at SimCloth.lua and I have a couple of sugestions:
1) In methods listcloth, listsim and listUDO it'll be better to declare f as
a local variable instead of as a parameter (e.g. function
SimCloth:listsim() local f="" ... return f end). Don't forget to remove the
parameter when you call those methods (e.g. self:listsim() instead of
self:listsim(f))
2) You use dostring at some places to declare global variables (e.g.
dostring("Distance="..self.core:povtolua(self.Clothvalue[1]))). Plugins
should not use global variables since you never now if another plugin will
use a global variable with the same name. It'll be better to rewrite those
as
local Distance=dostring(self.core:povtolua(self.Clothvalue[1]))
You don't have to change code where those variables are used though.
Andre de Leiradella
Date: 22 Oct 2004 12:06:17
Message: <41792ff9@news.povray.org>
Nice tool, thank you!
But I have a little problem.
It works fine with the included samples, but in my test scene
I'm not able to assign a material to the object: I've used standard
"black_white_cow" material and MegaPov (1.0) returns with this error:
texture { Black_White_Cow <----ERROR
Parse Error: No matching } in 'texture', material identifier found instead
Perhaps the quesion is: how can I made a texture (not a material) with
Moray?
Thank you in advance,
Paolo Gibellini
Date: 22 Oct 2004 13:32:39
Message: <41794437@news.povray.org>
"Paolo Gibellini" <p.g### [at] teinos com> a écrit dans le message de news:
41792ff9@news.povray.org...
> Moray?
Easy to do but not evident :-)
Just right-click on the material in the material editor, then click on
"Property/rename" in the scrolldown, then check "This is a mesh2..." box
done :D
Marc
Date: 23 Oct 2004 06:17:13
Message: <417a2fa9$1@news.povray.org>
> Hi Stephen,
> correct the bug.
Sorry for the confusion. The error message is from Pov-Ray. The solution was
also provided, use #undef first and then redefine. I was using a function
to contain Morays transformations, so I can apply them to the mesh being
created.
pov:write("#declare Object_trans = transform{")
pov:transforms(self.xforms)
pov:write(" }")
Pov-Ray code
#local f_Trans = function {transform {Object_trans}}
Pov-Ray code
#local xtemp=f_Trans(tempx,tempy,tempz).x;
#local ytemp=f_Trans(tempx,tempy,tempz).y;
#local ztemp=f_Trans(tempx,tempy,tempz).z;
To correct the error I add this to the end of the output
pov:write("#undef Object_trans")
Suggestions are most welcome :-)
as
the
> self:listsim(f))
At one time I was having problems creating and using Lua functions (basic
understanding). When I slowly started to get things to work I had this
format self:listsim(f), I've been afraid the change anything ever since :-)
> as
> Regards,
> Andre de Leiradella
I wanted to be able to use a text string, so I could:
enter simple math expressions, 3+1/16
use some declared variables, that the Lua plugin will understand
(wireframe)
Precision=2
9*Precision
simple pre-defined substitutions, Pov-Ray syntax to Lua syntax
from 'degrees' (pov) to 'deg' (Lua)
The dostring() seemed to be the only way to solve this, and have the Lua
plugin understand the resulting number for use in wireframes.
Thank you for looking at the code and suggesting better ways of doing
things. I will start using both immediately.
Date: 23 Oct 2004 06:43:58
Message: <417a35ee@news.povray.org>
417a2fa9$1@news.povray.org...
And that's great :D
Marc
SimCloth1a1.zip and
SimCloth_Samples_1a.zip
Comments welcome.
Date: 25 Oct 2004 03:40:51
Message: <417cae03$1@news.povray.org>
> done :D
Thank you for the tip!
Paolo
SimCloth1a3.zip
SimCloth_Samples1a1.zip
You can now select a material or texture. If 'texture' has an entry then
material is ignored. Wind pigment has moved to this new control.
Constraints are done by the colour of an image map RGB for x,y,z; if I get
it working fully :-)
For a 30x30 simcloth{} my plugin gives(watch for word wraps)
#local f_Constraint = function {pigment{Material2}}
#local I=0;
#while (I <= 30)
#local J=0;
#while (J <= 30)
#write(file,(I*30)+I+J,",",f_Constraint(I/30,J/30,0).x,",",f_Constraint(I/30
,J/30,0).y,",",f_Constraint(I/30,J/30,0).z,"\n")
#set J=J+1;
#set I=I+1;
However the resulting simcloth file has
217, 0.000000000000, 0.000000000000, 0.000000000000,
248, 0.000000000000, 0.000000000000, 0.000000000000,
279, 0.262744992971, 0.262744992971, 0.262744992971,
310, 0.260048985481, 0.260048985481, 0.260048985481,
341, 0.262744992971, 0.262744992971, 0.262744992971,
The individual indexes can have different values but the x,y,z seem to
always be the same. Still working on a solution.
Comments welcome.
SimCloth_Samples1a2.zip now available for download linked from
Comments welcome.
