POV 3.6.1 goes into la-la land when I attempt to render a
scene a second time via Moray, at least once bringing the
rest of my system to its knees (no small feat with winXP).
For now I'll go back to 3.5...
Tim Cook
Version: 3.12
I have the same problem, and I have done the same turn back to povray 3.5
news:41300280@news.povray.org...
> Tim Cook
> http://home.bellsouth.net/p/PWP-empyrean
> -----BEGIN GEEK CODE BLOCK-----
> Version: 3.12
> GFA dpu- s: a?-- C++(++++) U P? L E--- W++(+++)>$
> N++ o? K- w(+) O? M-(--) V? PS+(+++) PE(--) Y(--)
> PGP-(--) t* 5++>+++++ X+ R* tv+ b++(+++) DI
> D++(---) G(++) e*>++ h+ !r--- !y--
> ------END GEEK CODE BLOCK------
> r�y
> "Timothy Cook" <z99### [at] bellsouthnet> a �rit dans le message de
Lala land? Mine works just fine on 98...
What I have noticed though is that I need to select any other tab than the
one containing the exported file (in the Pov editor) before Moray 3.5 will
export...
Stefan Viljoen
Software Support Technician
Polar Design Solutions
Its working fine for me, with XP and 3.6.1.
Greets
Arne
Stefan Viljoen <rylan@ schrieb:
>>r�y
> export...
"Timothy Cook" <z99### [at] bellsouthnet> schreef in bericht
Using Windows ME.
I turned back to 3.5 for some other reasons, especially the impossibility to
stop a render in Moray when running 3.6.
But also, probably for reasons outside Moray or POV, because Moray got
corrupted and I had to reinstall.
Hi Timothy Cook, you recently wrote in moray.win:
Note also, that 3.6.1 can display highlights with strange color bleeds
in the Moray window. POV-Rays Render window should be fine.
- Lutz
- Lutz
email : lut### [at] stmuccom
Web : http://www.stmuc.com/moray
I also get some strange color shifts when continuing a trace. But i'm
pretty sure that it's not moray-related.
Arne
> - Lutz
> - Lutz
My POV 3.6.1 locked up solid on a second render with the latest MORAY. I
went back to 3.5 (POV Ray) and all worked.
Neil
> Neil
Same here. (W98SE)
Txemi Jendrix
www.txemijendrix.com
