I do'nt know if somebody has still asked this:
Is it possible in a future relase, for the ambient and rgb colors, to get
values over 1.0; Pov-ray can calculate values till 100!
So, when using radiosity, we could have better results with the sky texture
using such an ambient value.
friendly
rémy closset
I support this idea !
Friendly
Sylvain
"Remy Closset" <NOS### [at] tiscali fr> a écrit dans le message de
news:40d19dd1$1@news.povray.org...
> Hi,
texture
> friendly
> rémy closset
If it's possible to create negative values for all the normals:
A bump or a hole.. etc
Great
Sylvain
> Hi,
texture
> friendly
> rémy closset
On Thu, 17 Jun 2004 15:34:14 +0200, "Remy Closset"
<NOS### [at] tiscali fr> wrote:
>Hi,
I would like to see this too.
Regards
"Stephen McAvoy" <mca### [at] aol com> a écrit dans le message de news:
9te3d09i9pcn2cfgkh6ho5pol0f1tndul2@4ax.com...
Count me as well :-)
Marc
I didn't know there's such a limit in POV-Ray.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
I've used arbitrarily high vales with Moray...1000000
IIRC, trying to fake HDRI. Direct code, don't leave
home without it. (Direct code texture in Moray, that
is...)
Tim Cook
Version: 3.12
Ok, direct code exists.
But I do'nt see then the interest to have a material editor with the limits
of 1 !!!!
The best would be that moray should correspond exactly to the povray values
in all the cases that it happens.
Most probably the moray develpers team had choosen to put limits for
pedaggogic target, and so the beginners should have no problems with
inexplicable rendering....
It's sure I appréciated this situation one year earlier when I started with
moray. Perhaps, an indication of average value in the material editor would
be desirable for those beginners...
rémy closset
"Timothy Cook" <z99### [at] bellsouth net> a écrit dans le message de
news:40d2139e$1@news.povray.org...
> is...)
> Tim Cook
> http://home.bellsouth.net/p/PWP-empyrean
> -----BEGIN GEEK CODE BLOCK-----
> Version: 3.12
> GFA dpu- s: a?-- C++(++++) U P? L E--- W++(+++)>$
> N++ o? K- w(+) O? M-(--) V? PS+(+++) PE(--) Y(--)
> PGP-(--) t* 5++>+++++ X+ R* tv+ b++(+++) DI
> D++(---) G(++) e*>++ h+ !r--- !y--
> ------END GEEK CODE BLOCK------
"Remy Closset" <NOS### [at] tiscali fr> schreef in bericht
news:40d27da1$1@news.povray.org...
with
would
This is an interesting aspect. If you have used Wings3D, you may know that
there is something called 'Advanced Menus' (if I remember the wording well).
If you enable that, all kind of extra options are available. For the
beginner, starting without the AM is a lot easier; for the expert, the AM is
a must.
I suggest that in a future version, something like this would be included
(if possible!). Remy's request could then be part of Moray's Advanced
Menus.
The idea of advanced menu is very nice
I support
rémy
"Thomas de Groot" <t.d### [at] inter nl net> a écrit dans le message de
news:40d2a8e2@news.povray.org...
> with
> would
well).
is
> a must.
> Menus.
> Thomas
On Fri, 18 Jun 2004 11:11:44 +0200, "Remy Closset"
>I support
So do I
Regards
If you're talking about internally, there isn't. I often use color values
greater than one for effect.
In the final image, however, the colors are clipped in the range [0,1].
Maybe this is what is being suggested? Such limitation is not the fault of
POV-Ray, however, but of the image file formats used. Not to mention the
fact that it would be impossible to display accurately.
....Chambers
