![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi Lutz :)
I'm an intensive user of Luis' InsertCode plugin
I often need to use an object created in moray in a macro or a piece of
code.
For example an object dropped on a heightfield by the trace() function
To get these objects #declared in Pov export file, I have to duplicate them
as referenced objects.
Should it be possible to have a check box close to the "export" one named
"declare" so that the object could be in the declarations section of export?
Does it make sense?
Thanx
Marc
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
news:408e5f68@news.povray.org...
> Hi Lutz :)
> code.
them
export?
> Does it make sense?
> Thanx
> Marc
Yes, it's a good feature, i think.
Not only for using InsertCode, but also to retrieve correctly one object in
a plugin, for example.
And It could be a new Attribut Object, like others. To solve compatibiliy,
this checkbox must to be checked if the object is referenced, and per
default not checked if not.
Luis
http://www.lightning-generator.org
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi Marc Jacquier, you recently wrote in moray.win:
I need to think of all the cases that this touches.... theoretically,
it should not be a problem, since the reference object already does
part of this....
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I support this idea
> Hi Lutz :)
> code.
them
export?
> Does it make sense?
> Thanx
> Marc
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
