If you look at moray.binairies you will see my last drawing.
I started with moray during june 2003.
The most important thing for the modeler would be the possibility to split a
quadrangular face in two parts, parallel with an edge.
rémy
On Tue, 23 Mar 2004 18:23:11 +0100, "Remy Closset"
<NOS### [at] tiscali fr> wrote:
>Hi,
>rémy
I second that!
Would be be very handy to be able to do that.
Bernd
Hi Remy Closset, you recently wrote in moray.win:
Well, I agree that this would be handy, and it might make it into a
future release :-)
For now, just to make sure you are aware of one workflow... this is
what I usually do:
Press 'D' (edge mode)
Select one edge (Shift-Click the edge).
Press 'S' (split edge)
Select the other edge.
Press 'S' (split it)
Press 'F' (face mode)
Select two triangles that make up one of the new quads you actually
wanted.
Press 'M' (merge faces)
Press 'N' (deselect all)
Select the other two triangles that make up the other new quad you
actually wanted.
Cheers,
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
Thanks for your response. You can imagine how difficult and long it is to
make use of the actual edge splitting method .
I any case, I thank you very much for your excellent work. I'll be waiting
impatiently the new release
friendly
rémy
"Lutz Kretzschmar" <lut### [at] stmuc com> a écrit dans le message de
news:07sb60htc3k65gepns3riq6rhav4ba5qu3@4ax.com...
split a
> future release :-)
> what I usually do:
> wanted.
> actually wanted.
> Cheers,
> - Lutz
How would you ideally like it to work? What do you want to be able to
do with what keys/buttons?
- Lutz
On Sun, 28 Mar 2004 10:30:20 -0800, Lutz Kretzschmar <lut### [at] stmuc com>
>- Lutz
Mhh...this is not so easy...I think...
1. I want to select a rectangular face
2. Then we need a button called: Split Face in 2/4 Faces
3. An optionbox/window could appear, asking to split in how many
faces( 2 or 4)
Splitting to 4 faces should be clear (symetrical, from center of all
edges) but splitting to 2 faces is bit more difficult, because there
are two solutions to this. (North-South <-or-> East-West)
Damn... I didn't think of that.
Maybe someone else has a good idea?!?
How do other modellers cope with this problem?
Bernd
Here is my proposal
First select two or more edges
Than split
The result is in the attached file
rémy
news:tc6e60djpftuaq4j8qm7eelhoqsl0kbif9@4ax.com...
to
> - Lutz
Download 'Faces.jpg' (62 KB)
Preview of image 'Faces.jpg'
Good News
I have implemented a splitting algorithm that allows you to select as
many edges as you like (instead of just one). Moray then splits the
edges according to specific rules. If you select all edges, splitting
works kind of like subdivision.
I need a few testers to test this feature, so if you use the mesh
editor and miss being able to split more than one edge please let me
know by replying here.
- Lutz
here (?)
Thats what you wanted?
Greets
Arne
> Good News
> - Lutz
I volunteer to test.
Steve Shelby
"Lutz Kretzschmar" <lut### [at] stmuc com> wrote in message
news:gfa870t82ntf715duoad72qa115v6umrtt@4ax.com...
split a
> Good News
> - Lutz
Sir! yes Sir!
Marc
"Lutz Kretzschmar" <lut### [at] stmuc com> a écrit dans le message de news:
> - Lutz
Hi Steve Shelby, you recently wrote in moray.win:
Please send me an email, the one I just sent you (to the address you
use here), bounced.
- Lutz
