POV-Ray : Newsgroups : moray.win : Rhino exported UDO to Moray Mesh? Server Time
27 Jul 2024 16:20:33 EDT (-0400)
  Rhino exported UDO to Moray Mesh? (Message 1 to 2 of 2)
Subject: Rhino exported UDO to Moray Mesh?
Date: 21 Feb 2004 12:37:43
Message: <40379767$1@news.povray.org>
I have a nurbs model made in Rhino3d that's been imported into Moray as a
UDO, but I am not able to convert it to a Moray mesh to add UV mapping. In
another case, I found a mesh off the net and converted it to a UDO using
rhino, and I am able to convert it to a mesh. What determines if a UDO can
be converted to mesh?
-Sean
Subject: Re: Rhino exported UDO to Moray Mesh?
Date: 21 Feb 2004 13:00:39
Message: <a37f30h7hupv7th9sico58p2r0j936v5ak@4ax.com>
Hi Sean Johnson, you recently wrote in moray.win:
Ususally you can't turn an UDO into a mesh, because an UDO does not
have face data. I did update the UDO format recently to support faces,
but I'm not sure that Rhino updated their exporter...
Basically, if you can see a solid representation in Moray, then you
can convert it to mesh, otherwise, you can't.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
