Does not function; POV gives the file/path not found error, and a search
of the hard drive for *.flr turns up...nothing.
It looks like the actual nkflare zip file was not included.
Download this file separately:
http://www.nathan.kopp.com/nkflare.htm
I unzipped nkflare5.zip in a new directory Moray\POVScn\NKFlare
The include file is for POV-Ray 3.1 and generates a warning
Warning: Refraction value unnecessary to turn on refraction.
A simple scene seems to render ok, with flares showing up.
Tim,
I've experienced "erratic" behavior in the past with the lense flare plugin
that's included with Moray (including having to search for and copy the old
.flr file.) I've had more luck with the other one that's listed on the
Plugins webpage... I don't remember what its called or who its by, but I
know it seemed a little more flexible because the "flare" was an actual
included entity that you could rotate and scale to animate it over time.
Just a thot...
-Kman
"Tim Cook" <z99### [at] bellsouthnet> wrote in message
news:4001990a$1@news.povray.org...
> Just a thot...
That's Chris Colefax's lensflare plugin, which I have, just not
installed.
Hi Tim Cook, you recently wrote in moray.win:
Indeed.... it seems to have been left out of the installation. Did you
find it? It's available at
It should go in a NKFlare subdirectory of your scene directory
(usually .\POVScn).
- Lutz
email : lut### [at] stmuccom
Web : http://www.stmuc.com/moray
Yep, I found it...but the scene its in is exhibitng some...odd
behaviour. Testing out to try to track the cause, as my scene
is itself fairly unusual.
