POV-Ray : Newsgroups : moray.win : Separating 3.3 and 3.5 Server Time
27 Jul 2024 18:33:46 EDT (-0400)
  Separating 3.3 and 3.5 (Message 1 to 3 of 3)
Subject: Separating 3.3 and 3.5
Date: 24 Nov 2003 15:14:13
Message: <3kp4svolvkk38osr1rhrhadm0qp4s6i959@4ax.com>
How can I get Moray 3.3 and 3.5 to use different directories for search paths,
plugin etc. Version 3.3 tries to load plugins for 3.5 and start a Ver 3.5 file
if it was the last one I used. I would like to keep them separate.
Regards
Subject: Re: Separating 3.3 and 3.5
Date: 25 Nov 2003 02:35:15
Message: <td16svk0qceqe4e3ojv48ucnautvcn7277@4ax.com>
Hi Stephen McAvoy <mcavoys[at]AOLdotCOM>, you recently wrote in
moray.win:
The MORAY.INI file in each directory needs a entry called
RegistryBase= in the [Settings] section (at the top by default).
So, you could set the MORAY.INI in the V3.3 installation like this:
[Settings]
RegistryBase=Software\SoftTronics\Moray For Windows V3.3\
and the MORAY.INI in the V3.5 installation like this:
[Settings]
RegistryBase=Software\SoftTronics\Moray For Windows V3.5\
Then each one should use seperate registry branches and thus different
settings.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 25 Nov 2003 04:31:05
Message: <ca86svkgp30ll9g06693mv0uc8nk35ng6f@4ax.com>
On Mon, 24 Nov 2003 23:35:19 -0800, Lutz Kretzschmar <lut### [at] stmuccom> wrote:
>settings.
Thanks
Regards
