Hi Stephen McAvoy <mcavoys[at]AOLdotCOM>, you recently wrote in
moray.win:
> How can I get Moray 3.3 and 3.5 to use different directories for search paths,
> plugin etc. Version 3.3 tries to load plugins for 3.5 and start a Ver 3.5 file
> if it was the last one I used. I would like to keep them separate.
The MORAY.INI file in each directory needs a entry called
RegistryBase= in the [Settings] section (at the top by default).
So, you could set the MORAY.INI in the V3.3 installation like this:
[Settings]
RegistryBase=Software\SoftTronics\Moray For Windows V3.3\
and the MORAY.INI in the V3.5 installation like this:
[Settings]
RegistryBase=Software\SoftTronics\Moray For Windows V3.5\
Then each one should use seperate registry branches and thus different
settings.
- Lutz
email : lut### [at] stmuccom
Web : http://www.stmuc.com/moray
