Is it not possible to have two normals within one texture? I thought maybe a
layered texture would do this, but only the last normal listed gets used.
Steve Shelby
> Steve Shelby
Direct code the texture? (Gotta love that feature of Moray 3.5)
Nice idea, but it doesn't seem to work. I tried it with many different
variations, and one texture always overrides the other, regardless of the
order they are in.
Steve Shelby
"Tim Cook" <z99### [at] bellsouth net> wrote in message
news:3fba1513$1@news.povray.org...
maybe a
used.
> > Steve Shelby
You probably want an average normal_map, but I don't remember if you can
create that with moray.
<1,1,3>hollow}text{ttf"timrom""Warp".1,0translate<-1,-.1,2>}// - Warp -
Yes you can : add normal>normal_map noise pattern>average
put your 2 normal moise patterns in the 2 entries
( entry position doesn't seem to matter)
I post the mtx on Moray.binaries
Marc
"Warp" <war### [at] tag povray org> a écrit dans le message de news:
3fba2455@news.povray.org...
Thank you. After reading Warp's post, I tried it out using the direct code
thing, and it worked. I was not aware that it could be done directly with
Moray's material editor. That's cool!
Steve Shelby
"Marc Jacquier" <jac### [at] wanadoo fr> wrote in message
news:3fba6730@news.povray.org...
> Marc
can
