POV-Ray : Newsgroups : moray.win : Cube.lua plugin Server Time
16 Jan 2026 20:49:08 EST (-0500)
  Cube.lua plugin (Message 1 to 10 of 10)
Subject: Cube.lua plugin
Date: 28 Sep 2003 18:55:06
Message: <3f7766ca@news.povray.org>
I have started a plugin to allow the use for fractions to define the size
and transformations of a box() object.
It can be found linked from
http://ca.geocities.com/morayplugin/
Cube1a.zip is about 5k
The scale and shear internal transformations are incomplete.
Comments welcome.
If the general idea of entering numbers into a 'text box' is appealing, I
may extend this to some of my other plugins.
Subject: Re: Cube.lua plugin
Date: 29 Sep 2003 11:58:57
Message: <3f7856c1$1@news.povray.org>
Thanks Stephen.
But can you give us some exemples ?
Friendly
Sylvain
Subject: Re: Cube.lua plugin updated
Date: 29 Sep 2003 23:28:23
Message: <3f78f857@news.povray.org>
Cube1a1.zip is about 5k
Can now select 'list symbolic output' or 'list numeric output'.
scale fixed
shear internal transformations are incorrect for displayed wireframe.
Comments welcome.
Date: 29 Sep 2003 23:36:44
Message: <3f78fa4c@news.povray.org>
Let me get the basic parts working first, then i'll make an example file.
The basic idea is to enter the start and finish points for a box(), default
is
box{<0,0,0>,<1,1,1>}. For example if you set 'finish x' to '5+3/32', the
plugin will output
box{<0,0,0>,<5+3/32,1,1>} for Povray.
Did this help?
Date: 2 Oct 2003 08:33:01
Message: <3f7c1afd@news.povray.org>
> I have started a plugin to allow ...
Cube1a2.zip now available.
The plugin has the following features:
   List symbolic output, displays a window with the code that will be output
to Povray. Simple expressions are maintained.
   List numeric output, displays a window with the code that is used to
display the wireframe. Simple expressions are evaluated to a single number.
   Simple expressions can be entered in 'text box', example 4+5.2-(16/3)
   Supported functions include:
sin(), cos(), tan(), asin(), acos(), atan2(),
abs(), exp, sqrt(),
ceil(), floor(), max(), min(), mod(),
   Indirectly supported are:
degrees(), radians(), ln(), log()
   Output is in the form of:
box {<x1,y1,z1>,<x2,y2,z2>
   (internal transformations)
scale
shear
rotate
translate
object flags (no_shadow...)
material
   (Moray transformations)
scale
rotate
translate
Comments welcome
Date: 2 Oct 2003 08:44:16
Message: <3f7c1da0$1@news.povray.org>
3f7c1afd@news.povray.org...
Eeerrrrrr are you sure your link works?
Marc
Date: 2 Oct 2003 12:41:06
Message: <3f7c5522@news.povray.org>
Salut Marc :
essaye : http://ca.geocities.com/morayplugin/Cube1a2.zip
pgb
news:3f7c1da0$1@news.povray.org...
> Marc
Date: 2 Oct 2003 13:31:39
Message: <3f7c60fb@news.povray.org>
3f7c5522@news.povray.org...
> Salut Marc :
Ah merci :)
oups I didn't even notice that the link pointed to version 1a1
Marc
Date: 2 Oct 2003 18:23:43
Message: <3f7ca56f@news.povray.org>
oops, will fix :-)
Date: 1 Dec 2003 15:42:38
Message: <3fcba7be@news.povray.org>
> I have started a plugin to allow...
Cube1a3.zip now available
includes Cube.lua and Sphere.lua(requires Cube1a3 or later)
Added a simple internal declare.
Anything before the first equal sign (=) will be replaced with anything
after the equal sign.
Substitution is in reverse order (last declared is applied first)
example:
m=*1
cm=/100
mm=/1000
2m+23cm+7mm
internally will be converted to (in steps)
2m+23cm+7/1000
2m+23/100+7/1000
2*1+23/100+7/1000
or
2.237
It's easy to confuse the plugin
mm=/1000
cm=/100
m=*1
from the previous example
2*1+23c*1+7*1*1
c is not a valid number, error!
There is reference to mesh2 and isosurface in the plugin, these are not
implemented yet.
Comments welcome
