You can find "glow.lua" plug in at moray.binaries
Friendly
Sylvain
Sylvain!
Just tried your plugin! It feels fine and does a good job. It is different
from Chris Huff's one, isn't it? I have not used that one for a long time
(in Moray 3.3) so I don't remember rightly.
With yours you can do interesting things, especially with the turbulence
settings.
For shadows... I don't know. Would be excellent for simulating smoke-like,
faintly glowing objects. Very spooky, or unhealthy in an atomic sort of
way...
"leseur sylvain" <syl### [at] potar-hurlant com> schreef in bericht
news:3f6f2e8e@news.povray.org...
> Friendly
> Sylvain
>Sylvain!
Thanks. Yes it is
It only works with Megapov O.7.
>settings.
>way...
Damn! Nobody can help me...
Can you see some improvements for this plug ?
>Thomas
Thanks Thomas but don't forget i just "translate" a macro into Lua language,
and add easy possibilities.
Friendly
Sylvain
Ps:What's news about SeaShell ?
Just a quick question: What do I do with the .lua file?
(I couldn't find the answer in Moray help files, in the Moray website
nor even browsing Moray's directory structure. This .lua file type seems
like an undocumented mystery.)
Warp <war### [at] tag povray org> escribió en el mensaje de noticias
3f733e76@news.povray.org...
Put it in the Plugins folder (you'll also need the
Fullmoon.dll file ).
Open Moray and it will appear in the buttons bar.
Hope this is the answer you're searching for.
Bye
Txemi Jendrix
http://www.txemijendrix.com
Txemi Jendrix <tji### [at] euskalnet net> escribió en el mensaje de noticias
3f735af5@news.povray.org...
> (you'll also need the Fullmoon.dll file ).
Sorry. Fullmoon.dll it's available at:
http://www.geocities.com/andre_leiradella/
See you
Txemi Jendrix
Ah, now I understand. The mystery is explained. Thanks. :)
<1,1,3>hollow}text{ttf"timrom""Warp".1,0translate<-1,-.1,2>}// - Warp -
news:3f732287@news.povray.org...
==> Life is hard ;-}
===> Hmm... What about the switch possibility between keeping the glow
always on top, or (like now) partly hidden by objects in front? This is
something that is implemented in the LensFX plugin, based on Chris Colefax's
macro. That would be a useful addition. The standard LensFlare of Moray
does not have it and that's a pity!
language,
==> Sure. But that is an important job. Much appreciated anyway!
==> Aah! Still have to do something with it! Time, you know, and too many
different projects at the same time!!
Colefax's
Are you really shure ....?
Do you know LensFXMFC.dll There is in a button "Always on top" but i
can't see none difference....
In fact, i don't understand, what is "always on top" ?
One thing more and i stop that.
What do you wish exactly when you say:
Colefax's
> macro.
If i can do that it will be a "grand plaisir pour moi"
Friendly
Sylvain
Download 'LensFXMFC.dll.dat' (156 KB)
"leseur.sylvain" <les### [at] wanadoo fr> schreef in bericht
news:3f75cfb5@news.povray.org...
> Colefax's
> > macro.
==> Yes, that is the plugin I mean! "Always on top" means that, whatever is
in front of the lens flare, it always shines through. If you put it behind,
say, a thick wall, when rendering you who still "see" the flare. If you
uncheck the "always on top", then you have the situation where the flare is
hidden and not visible. In a sense that sounds obvious and rather silly (who
wants an invisible flare?), but there are situation where you want to try
out both possibilities, for instance when the light is partly hidden. For
animations, I don't know, I am not an animator, but I imagine the same may
apply.
==> Merci! Merci!
is
behind,
is
(who
> apply.
> ==> Merci! Merci!
> Thomas
I'm not able to do "Always on top" I try, try again. Nada...
I don't know how to do that. It's a pity...
Sorry
Friendly
Sylvain
news:3f8a493e@news.povray.org...
> Sorry
Don't worry! It is not such an important option I think. As it is now, It
has all the functionalities that matter.
Ah, by the way, I think It may come in handy for the "Christmas tree"
tribute!!!
Best wishes,
