I've been working on something that requires making multiple duplication of
an object (about 300 duplicates), but requires something that Moray's
duplication dialogue box does not seem to be up to. Each duplicate needs to
be 0.04 units larger than the preceding one, and translated along x in
proportion to its increase in size. This works out to
translation=scale*0.0096154*duplicate's serial number (1st duplicate is #1,
2nd is #2, etc.)
For example, duplicate #1 is scale 1.04*0.0096154*1=trans .01, dup. #2 is
scale 1.08*0.0096154*2=trans 0.0207692, dup. #3 is scale
1.12*0.0096154*3=trans 0.0323076, and so on.
Is there an easy way to do this in Moray or Povray without having to hand
calculate all 300 duplicates?
Thank you,
Steve Shelby
On Sat, 12 Jul 2003 17:42:49 -0500, "Steve Shelby" <ssh### [at] rexnetnet> wrote:
>Hi,
>2nd is #2, etc.)
>Thank you,
>Steve Shelby
Well for the first part try Scaling - Offset 0.04 This gives what you want I
think.
As for the translation I'm not too sure, try moving the original object away
from the origin and Translate - Factor.
BTW I would usually try small numbers of copies and largish displacements to
start with
Regards
