POV-Ray : Newsgroups : moray.win : Look_like Bulb Server Time
11 Nov 2026 20:16:39 EST (-0500)
  Look_like Bulb (Message 1 to 2 of 2)
Subject: Look_like Bulb
Date: 12 Jul 2003 15:52:31
Message: <3f1066ff$1@news.povray.org>
Hi all,
I know, this has been discussed several times but I`m not able to get a
looks_like effect of a Bulb. I downloaded a chandelier from 3D cafe and
wanted to illuminate the bulbs. I converted the 3ds file with 3dwin and put
the bulb together with the pointlight in a group object. For the bulb, no
shadow has been checked. I tried to adapt the texture but it doesn't work.
Help is very appreciated
Robert
Subject: Re: Look_like Bulb
Date: 16 Jul 2003 05:58:33
Message: <3f1521c9$1@news.povray.org>
Hi there Robert,
You can achieve the looks_like effect in Moray
by adding the object/object together with a point
light in a CSG union. Turn the shadow off for the
whole union. Now, when it comes to getting the,
in your case, light bulbs to look like real ones
normally a ambience setting around 1 on all the
textures does the trick. The problem is that when
you use image maps you have to "fix them" yourself
in <fill in your favourite pixel handling program here>
so that the image map looks like a bulb that is lit.
Try it with a simple sphere and pointlight first
and create a whiteyellow texture with ambient set to 1.
Hope this helps.
/Stefan"Robert" <rgu### [at] exmailde> wrote in message
news:3f1066ff$1@news.povray.org...
> Hi all,
put
> Robert
