Philippe,
Impressive plugin. Thanks for the work! A few comments, perhaps bugs(?)
The pre-defined shape 'coquille' is the basis for all lamellibranch and
brachiopod shells, so mostly the bivalve class. I think the name should be
changed to 'lamellibranch', as more specific.
Maybe a bug: when changing parameters in, for instance, coquille, and
switching then to ammonite, the shape inherites the changed parameters (at
least it looks so when viewing the wireframe which is not the basic shape
anymore). As far as I can tell, this only happens to the ammonite. All other
selections show the basic one. Deleting the shell and restarting the plugin,
of course shows the correct ammonite shape.
Maybe another bug, I am not sure: Several times while changing parameters,
Moray froze. Only way out was ctrl-alt-del and restart Moray, although the
mdl was corrupt sometimes and had to be deleted before (due to the crash
exit, no doubt). It may be that the freeze happened because of an
incompatible parameter value (too high for instance) so that the wireframe
update took too long or was not possible.
That's it for now,
"Philippe_Gibone" <Ph.### [at] wanadoo fr> schreef in bericht
news:3ee2e3c8@news.povray.org...
> Hi there,
> Here is the beta version of SeaShell (which does what the name suggests).
> It's a FullMoon plugin so you need fullmoon.dll. You just have to copy the
2
> files (fullumoon.dll et seashell.lua) moray\plugins directory.
> An explanation about the model and its parameters can be found at
> http://www.math.arizona.edu/~lega/195/Fall99/lectnotes/lect8/sld002.htm.
> Starting from the "official" model I added :
> Ripples : small ripples on the generating curve, it gives the jagged
aspect
> of some shells (have a look at "Coquille"), usual values are around 50-100
> (you'll need vrey small steps in this case, and it'll be time consuming)
> Wave : Frequency lower than Ripples it changes the overall shape of the
> shell (value between 0 & 20)
> My advice l : allways start from a pre-definite shell (I've got 6 more),
> you can give birth to scary monsters if you want (and sometimes when you
> don't want to)
> Beta Version :
> This version is fully functionnal (predefined set of parameters, choice
for
> every parameter, wireframe and POV export )
> Known Bug : when you choose a predefined Shell in the listbox, the
> parameters are updated so the wireframe, but the dialog part of the screen
> is not updated. I don't know if it is a FullMoon bug (I asked the author),
> or if there exists a function that I don't know, sort of UpdateWindows (if
> any one knows it...). A turnaround : select another object (even a light
or
> a camera), then selectionner the shell : the good parameters are
displayed.
> Version 1 :
> Correction of the bugs you'll found
> Optimisation of the wireframe which is a bit slow
> Version 2, 3... : (in the order you'll suggest)
> The ability to define different steps for the wireframe and the rendering
> To have a smaller resolution around the bumps
> uv_mapping texturing
> Texture using the mesh2 capabilities
> New functions for the structural curve
> New functions for the genrating curve (Bézier if possible)
> New functions for the waves
> Thanks for your comments and criticism
> pgb
Hi Thomas
Thanks for being concerned.
I agree ("coquille" is a very generic name in french) , and will do it
other
plugin,
I think all your problems come from the known bug :
When you choose a predefined Shell in the listbox, the parameters are
updated so the wireframe, but the dialog part of the screen is not updated.
I don't know if it is a FullMoon bug (I asked the author), or if there
exists a function that I don't know, sort of UpdateWindows (if any one knows
it...). A turnaround : select another object (even a light or a camera),
then selectionner the shell : the good parameters are displayed.
I experienced the freezing of Moray when I forget to select another object,
then select back the shell.
pgb
Yep!!!
That's the spirit!!
Good show!
"SYLVAIN LESEUR" <sle### [at] free fr> schreef in bericht
news:3ee47417@news.povray.org...
> Some pictures with SeaShell
> Sylvain
or
displayed.
I have the same problems with my plugins. I have not been able to find a way
around this limitation.
> Version 1 :
Very cool :-)
Could you add support for the Object flags (no_image, no_reflection,
no_shadow...) and a Photons block.
> > Known Bug
way
I had the answer from Andre : replace all the EditBox by TextEdit (you lose
the controls, but it works)
I feel theese points are more a Moray than a plugin concern, so I'll wait
until the V 3.5 of Moray to see if it is included.
Thanks for your time
Philippe Gibone
In article <3ee47417@news.povray.org> , "SYLVAIN LESEUR" <sle### [at] free fr>
> Sylvain
Please do not post binary attachments in non-binary groups. For details,
please read:
Newsgroups: povray.announce.frequently-asked-questions
Subject: Welcome To The POV-Ray News Groups
Message-ID: <3D4C20DA.40C33E49@pacbell.net>
Date: Sat, 03 Aug 2002 11:28:42 -0700
Thanks,
Thorsten
"Thorsten Froehlich" <tho### [at] trf de> a écrit dans le message de news:
3ee83702$1@news.povray.org...
> > Sylvain
> please read:
> Thanks,
> Thorsten
OK Sorry
Sylvain
Some comments below. Priority order given:
==> Priority 5.
> To have a smaller resolution around the bumps ==> hm. Not ested. Priority
somewhere in th middle I guess.
> uv_mapping texturing ==> Yes, this would be nice. Priority 1. Also with
exterior and interior texture definition possibility. Most shells in nature
are pearly white on the inside, while coloured on the outside.
> Texture using the mesh2 capabilities ==> Yes, absolutely! Priority 2. Now
it gives an error in POV.
> New functions for the structural curve ==> Priority 3.
> New functions for the genrating curve (Bézier if possible) ==> Priority 4.
> New functions for the waves ==> Priority 6.
Cheers,
Philippe,
What I forgot to suggest, was to include also (if possible) some predefined
textures like those from Sylvain, which are excellent ones and good starting
points to define ones own.
rendering
> ==> Priority 5.
Done in version 1 (very easy, and very convenient the redraws are very fast)
Priority
I'd like to put this one in version 2
>Also with exterior and interior texture definition possibility. Most shells
in nature
Done in version 1, with a little problem : mesh2's accept an
"interior_texture", but no "material_texture", you can define texture
instead of material in Moray, but I don't know if it is possible to force
the user to select a testure and not a material for the inside. I'm yhinking
about giving a thickness to the Shell, this would solve the problem but
would multiply the parsing time by 2 !
Now
I don't get what kind of error you mean, by mesh2 capabilities I was
thinking of :
"To specify a texture for an individual mesh triangle, specify a single
integer texture index following the face-index vector for that triangle.
To specify three textures for vertex-texture interpolation, specify three
integer texture indices (separated by commas) following the face-index
Vertex-texture interpolation and textures for an individual triangle can be
mixed in the same mesh"
and it is not yet in the code.
4.
I'd like to put this one in version 3
About joining some textures (including a "the mother of all pearl"
texture ), I agree with you and I've allready asked Sylvain about that...
Cheers, and thanks for being concerned
Philippe Gibone
Philippe,
All fine concerning your priorities and comments.
Just one thing concerning the mesh2. As you know, you can make mesh2
textures in Moray 3.5 (in fact without 'material'). However, if you select
such a texture for the SeaShell, an error is generated in POV saying:
material { T <----ERROR
Parse error: no matching } in 'material', undeclared identifier 'T' found
instead
In fact, in the pov file of the scene, the mesh2 texture is defined as a
material and not as a texture (while it is so in the inc file). Ah! and
underscores are not suported (but I should have known this, I think).
If you change the POV file, the scene renders ok.
Sorry but I don't use Moray 3.5 yet.
In Moray 3.3 you can check 'this is a mesh2 texture', then Moray generates a
texture, not a material (not sure this is the problem, though)
Inside the lua plugin, I have no problem defining a "material" for the
"texture" of my mesh2, and a "texture" for the "interior_texture", but I
have to be carefull when I choose them !
Philippe
news:3eec9c12$1@news.povray.org...
a
==> yes it is, in the case of a mesh2 texture made in Moray: when you open
the generated pov file, you see that it is a 'material' that is called for,
with the name of a 'texture', hence the error call from POV.
Example:
TUVMesh is checked in Moray (3.3 or 3.5) as a mesh2 'texture' and so does
not bear the term 'material'.
Rendering generates an error in POV. Opening the pov file, this is what is
written:
material { TUVMesh }
So, there is a contradiction: POV expects a 'material' but only sees a
'texture'.
Changing manually 'material' into 'texture' solves the problem. But it is a
workaround.
==> It seems to be better to stick to 'material', but I wonder what would
happen if you develop further towards uv-mapping etc. As far as I can see in
Moray, you cannot put a 'material' on a mesh2 object, nor a mesh2 'texture'
on a regular object... This is somewhat confusing I think...
How do you do this? I mean especially the 'interior_texture'? I experimented
a little (in Moray it is not implemented as far as I can see, I asked Lutz
if he could though) and adding the command in POV results also in errors...
Hi Thomas
I don't see the post i wrote this morning, so, I do it again, sorry if you
have allready seen it
pov:write("interior_texture{", gsub(self.TextureInterior, "%s", "%_"),"}")
pov:texture(gsub(self.Texture, "%s", "%_") )
The first line will generate a line in pov :
"interior_texture{TextureInterior}"
The second line will generate a line in Pov like material {Texture}
(The call to gsub avoid the spaces in the name of the texture)
But TextureInterior MUST be a texture and Texture MUST be a material (sorry
for shouting ;-)
HTH
Philippe Gibone
"Thomas de Groot" <t.d### [at] inter nl net> a écrit dans le message de
news:3eed8a51@news.povray.org...
experimented
errors...
> Thomas
Thanks a lot Philippe!
Just opened my mail, so have not had time to experiment further. But looks
good!
thanks for shouting ;-))
news:3eee02e7@news.povray.org...
> Hi Thomas
"%_"),"}")
(sorry
> for shouting ;-)
> HTH
> Philippe Gibone
I
> experimented
Lutz
> errors...
> > Thomas
