I've been playing with the isosurface plugin, and trying out some things I
found on various websites, most of which were apparently written for
MegaPov, and won't parse in PovRay3.5. The problem is, I havn't a clue how
to change them to work with PovRay3.5. Here's an example:
#declare Cracks = function { pigment{ crackle color_map{ [0 rgb 1][1 rgb
0] }}}
function {(x*x+y*y+z*z-1) +Cracks(x, y, z)*0.5}
Here's what Pov gives me:
File: isocrackle.pov Line: 96
(x*x+y*y+z*z-1) + Cracks( x, y, z )
} <----ERROR
Parse Error: Expected '.', } found instead
Returned from renderer with error status
That doesn't make any sense to me. There are several others I've tried with
similar results. Does anyone know how to make this work?
Thank you,
Steve Shelby
Oops,
The example I showed could be misleading, because I had eliminated the "*5"
at the end of the function just to see what would happen. Here's the message
when the function is complete:
File: isocrackle.pov Line: 95
function {
(x*x+y*y+z*z-1) + Cracks( x, y, z ) * <----ERROR
Parse Error: Expected '.', * found instead
Steve Shelby <ssh### [at] rexnet net> wrote in message
news:3e1ca8fc@news.povray.org...
> Hi,
> 0] }}}
> } <----ERROR
with
> Thank you,
> Steve Shelby
Steve Shelby wrote:
>Oops,
> function {
Consult the POV-Ray 3.5 documentation and also take a look at this website
http://www.econym.demon.co.uk/isotut/pov35.htm
Thorsten
As you use the evaluation of a pigment as a function, you should tell to pov
which color component you want to use:
(x*x+y*y+z*z-1) + Cracks( x, y, z ).gray*5
That's the "." meaning
see the link given by Thorsen (bottom of the page)
Marc
"Steve Shelby" <ssh### [at] rexnet net> a écrit dans le message de news:
3e1caaeb@news.povray.org...
> Oops,
"*5"
message
> function {
> > Hi,
I
how
> > 0] }}}
> > } <----ERROR
> with
> > Thank you,
> > Steve Shelby
Thorsen, Marc,
Thank you both for the helpful suggestions. That particular problem is
solved.
Now to tackle "ridges". ;~^}>
Steve
Marc Jacquier <jac### [at] wanadoo fr> wrote in message
news:3e1cb7f1@news.povray.org...
pov
> Marc
Steve Shelby wrote:
>Hi,
>0] }}}
> } <----ERROR
Now that you have found a solution,
you may find it interesting that this
will give the same results:
#include "functions.inc"
#declare CracksFn=function{pattern{crackle}}
function{(x*x+y*y+z*z-1)+(1 - CracksFn(x, y, z))*0.5}
Tor Olav
Tor Olav,
Thanks. That is a much simpler way to do it.
Steve
Tor Olav Kristensen <tor### [at] hotmail com> wrote in message
news:web.3e1d81ad5fe0597fb417814a0@news.povray.org...
> Tor Olav
