POV-Ray : Newsgroups : moray.win : looks_like light Server Time
27 Jul 2024 20:35:05 EDT (-0400)
  looks_like light (Message 1 to 9 of 9)
Subject: looks_like light
Date: 13 Oct 2002 16:45:26
Message: <3da9db66$1@news.povray.org>
Hi everyone, I've got a little question. I'm probably just overlooking it
somehwere but could anyone tell me how to make a 'looks_like {object}' light
in moray? I don't see the option in the modify tab for lights.
Thanks in advance,
Owen
Subject: Re: looks_like light
Date: 14 Oct 2002 14:55:46
Message: <MPG.1815236a836deddd989bec@news.povray.org>
In article <3da9db66$1@news.povray.org>, owe### [at] muzikantenbanknet says...
> Thanks in advance,
> Owen
Moray frequently asked question No. 23b  <grin>
Create the item you want your light to look like.  Check the No Shadow
check box.  position your point light (or whatever) inside said object.
Jamie.
Date: 14 Oct 2002 15:14:47
Message: <MPG.1815281e5b1b4661989bee@news.povray.org>
                                   Select the root level of the object.
                                                   V
Jamie.
Date: 14 Oct 2002 16:19:05
Message: <3dab26b9$1@news.povray.org>
Does that really do the same thing as the looks_like flag?
Tim Cook
Version: 3.12
Date: 14 Oct 2002 16:40:12
Message: <MPG.18153c1a5793e1e0989bef@news.povray.org>
IIRC, it does manually what POV does internally when you set looks_like.
Jamie.
Date: 15 Oct 2002 04:30:55
Message: <3dabd23f@news.povray.org>
  Internally the looks_like object is also translated by the location
of the light source.
Date: 15 Oct 2002 12:24:29
Message: <3dac413d@news.povray.org>
3dabd23f@news.povray.org...
Just create a group, add both light and "looks_like" object and apply
transformations to the group
Marc
Date: 15 Oct 2002 15:32:12
Message: <MPG.18167db18b0ba6ee989bf1@news.povray.org>
The advantage to me of doing it manually is that you don't need to
create the looks_like object with the origin in the right place, you can
build it however you like and manually position where you want the light
source to be :)
Or maybe I'm just weird :)
Jamie.
Date: 17 Oct 2002 07:05:47
Message: <3dae998b$1@news.povray.org>
Thanks for the help!
"Jamie Davison" <jam### [at] ntlworldcom> wrote in message
news:MPG.1815281e5b1b4661989bee@news.povray.org...
>                                                    V
> Jamie.
