POV-Ray : Newsgroups : moray.win : uv mapping simple?? Server Time
11 Nov 2026 20:36:46 EST (-0500)
  uv mapping simple?? (Message 1 to 9 of 9)
Subject: uv mapping simple??
Date: 25 Sep 2002 11:45:05
Message: <3d91da01$1@news.povray.org>
Hi all,
i`m going to rework an old model of mine and wanted to visiualize in moray a
pictured plane in order to make modelling easier. So, i created a plane for
an archit (hope, this is the right word) and wanted to "project" the desired
pic on it. Tried it with uv mapping (the only way so far, i think, for
seeing the pic directly in moray, refrained from background pics). I
converted the plane into a mesh2 object and used a image texture (using
"this is a mesh2 texture..."). I know, "no transformations are allowed".But
how to fix the pic in the right dimensions?? I always see just distorted
cutting of the picture.
Tried to rezise the original picture with an painting program to the size of
the desired plane but no effect.
Unfortunately, i have no idea...
Help is very apprechiated,
best wishes,
Robert
Subject: Re: uv mapping simple??
Date: 25 Sep 2002 15:31:33
Message: <5c34pu0lqfiun5411qikbf5t8qdgijosgi@4ax.com>
Hi Robert, you recently wrote in moray.win:
> But how to fix the pic in the right dimensions?? I always see just distorted
Mesh Editor.
Got to Face mode.
Select the faces that you want to change.
Make one of the views a UV view.
On that UV view, you will see the bitmap spanning the 0 to 1 ranges in
both dimensions and you will see the UV vertices of the selected
faces.
You then work in the UV view to drag the vertices so that the
projection works as you want.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 25 Sep 2002 16:33:16
Message: <3d921d8c@news.povray.org>
Thanks for the hint!
After a lot of trying, i found it out by myself....
best wishes,
Robert
"Lutz Kretzschmar" <lut### [at] stmuccom> schrieb im Newsbeitrag
news:5c34pu0lqfiun5411qikbf5t8qdgijosgi@4ax.com...
distorted
> Mesh Editor.
> Got to Face mode.
> faces.
> - Lutz
Download 'nautilus_uv2.jpg' (111 KB)
Preview of image 'nautilus_uv2.jpg'
Date: 25 Sep 2002 16:36:42
Message: <3d921e5a@news.povray.org>
Nevertheless,
i apprechiate a lot the support of you ;-)
Robert
"Robert" <rgu### [at] exmailde> schrieb im Newsbeitrag
news:3d921d8c@news.povray.org...
> best wishes,
> Robert
> distorted
> > Mesh Editor.
> > Got to Face mode.
> > faces.
> > - Lutz
Date: 25 Sep 2002 19:06:51
Message: <3d92418b$1@news.povray.org>
Are you making a 3d model of the Nautilus?
Can I have?  ^_^;
Tim Cook
Version: 3.12
Date: 27 Sep 2002 06:46:15
Message: <3d9436f7@news.povray.org>
Yes and no. I did it already, but i have to rework a lot of details.
So, please be patient.
BTW, what exactly do you want to have?
best wishes,
Robert
"Timothy R. Cook" <tim### [at] scifi-fantasycom> schrieb im Newsbeitrag
news:3d92418b$1@news.povray.org...
> Can I have?  ^_^;
> Tim Cook
> http://empyrean.scifi-fantasy.com
> mirror: http://personal.lig.bellsouth.net/lig/z/9/z993126
> -----BEGIN GEEK CODE BLOCK-----
> Version: 3.12
> GFA dpu- s: a?-- C++(++++) U P? L E--- W++(+++)>$
> N++ o? K- w(+) O? M-(--) V? PS+(+++) PE(--) Y(--)
> PGP-(--) t* 5++>+++++ X+ R* tv+ b++(+++) DI
> D++(---) G(++) e*>++ h+ !r--- !y--
> ------END GEEK CODE BLOCK------
Date: 27 Sep 2002 07:05:53
Message: <3d943b91@news.povray.org>
*evil grin*
I want a 3d model of the Nautilus with interior and exterior, and
lots of pretty CSGs.
Tim Cook
Version: 3.12
Date: 27 Sep 2002 07:27:30
Message: <3d9440a2@news.povray.org>
So,
that`s the same i want ;-))
I'm working in that (at least at the exterior)..
Robert
news:3d943b91@news.povray.org...
> *evil grin*
> Tim Cook
> Version: 3.12
Date: 27 Sep 2002 07:29:00
Message: <3d9440fc@news.povray.org>
BTW, i`m working on that (not in that)...
news:3d9440a2@news.povray.org...
> So,
> Robert
> > *evil grin*
> > Tim Cook
> > Version: 3.12
