POV-Ray : Newsgroups : moray.win : HamaPatch Question Server Time
16 Mar 2026 01:17:05 EDT (-0400)
  HamaPatch Question (Message 1 to 4 of 4)
Subject: HamaPatch Question
Date: 21 Jul 2002 11:12:21
Message: <3d3acf55@news.povray.org>
I finally got started using HamaPatch, after having it for about a year. I
was making something in Moray, and found that part of it would be impossible
with Moray. Here's my problem:
I made an irregular spline that is half of a symetrical spline that I want
to extrude. To get the second (right) half to match the first (left), I
copied, pasted, and rotated to get two matching halves. I then welded the
common center point. It appears to be one spline; I can select all the
points and move it around, but when I click on "extrude", all the points on
the right side get de-selected, and only the left side will extrude. I've
tried it several times in different ways, always with the same results. What
am I doing wrong?
Thank you,
Steve Shelby
Subject: RE: HamaPatch Question
Date: 21 Jul 2002 17:17:09
Message: <3d3b24d5@news.povray.org>
3d3acf55@news.povray.org...
on
What
> am I doing wrong?
Sometimes I get the same behaviour in Hamapatch.
One thing that usually works for this is:
When you got the half spline, clone it.
Then flip it in the axis you need to (model -> flip (whatever axis))
Close the spline.
Extrude it
Usually that works.
Hope this helps.
Txemi Jendrix
tji### [at] txemijendrixcom
http://www.txemijendrix.com
Subject: Re: HamaPatch Question
Date: 21 Jul 2002 17:37:07
Message: <3d3b2983@news.povray.org>
I tried that, and it still does the same thing. I think it must have
something to do with the way I'm connecting the two halves. I'm going to
look at the tutorials and see if I can find a clue there.
Steve
Txemi Jendrix <tji### [at] euskalnetnet> wrote in message
news:3d3b24d5@news.povray.org...
want
the
> on
I've
> What
> > am I doing wrong?
> Close the spline.
> Extrude it
> Usually that works.
> Hope this helps.
> Txemi Jendrix
Date: 21 Jul 2002 17:44:25
Message: <3d3b2b39@news.povray.org>
3d3b2983@news.povray.org...
If you want, send me the hamapatch file so I can take a look.
Txemi Jendrix
