POV-Ray : Newsgroups : moray.win : incompatible camera with pov b10 Server Time
11 Nov 2026 20:58:37 EST (-0500)
  incompatible camera with pov b10 (Message 1 to 9 of 9)
Subject: incompatible camera with pov b10
Date: 16 Jan 2002 05:12:18
Message: <3c455202$1@news.povray.org>
Help me please.
I am a registered user of Moray3.3+aPatch.
The camera statements is changed in POV beta 10, so all scenes
created with Moray changed the shot.
One more problem: when POV+Moray run into a  parsing parsing it crashes.
Thanks.
Ceggi
Subject: Re: incompatible camera with pov b10
Date: 16 Jan 2002 05:19:55
Message: <vkka4uo351uh763jr7mauoq1r1f49ct3o4@4ax.com>
On Wed, 16 Jan 2002 11:04:33 +0100, "ceggi" <ceg### [at] tiscalinetit> wrote:
> Help me please.
I don't know Moray very well becouse I'm script user but I try.
1. Have you tried uninstal 3.5 and install 3.1 ?
2. Please save scene as script and check if there is any #version declare in
files. If not add at begining of every script:
#version 3.1;
There is nothing to do without script so try generate script and post it
somewhere to continue helping.
ABX
Date: 16 Jan 2002 05:39:12
Message: <3c455850@news.povray.org>
"ceggi" <ceg### [at] tiscalinetit> ha scritto nel messaggio
news:3c455202$1@news.povray.org...
Sorry.
> One more problem: when POV+Moray run into a  parsing error it crashes(it
seems to run in a loop and i must ctrl+alt+del for exit).
> Thanks.
> Ceggi
Date: 16 Jan 2002 12:00:26
Message: <3C45B1FC.1070606@exmail.de>
I have the same problem with crashing, when povray runs into a problem
during parsing. If i try to start pov on it's own and there is a problem
(e.g. inc-file not found, cause i have not declared the right path in
the ini file with the +L comand) i get an error message, but i can
proceed working (after solving the cause). Doing it out of Moray
(rendering), i have to shut down pov AND Moray with the Task-manager....
Robert
ceggi wrote:
> Help me please.
> Thanks.
> Ceggi
Date: 16 Jan 2002 20:51:54
Message: <3c462e3a@news.povray.org>
yes, thats one of those undiscovered bugs in pov3.5 - it crashes for
everyone, and no one knows why....
PGP Public Key
Date: 17 Jan 2002 03:12:28
Message: <qn1d4ucau4680uqecmpa979amkjvavbltb@4ax.com>
On Thu, 17 Jan 2002 01:24:12 -0000, "Rick [Kitty5]" <ric### [at] kitty5com> wrote:
You mean it crashes _with_ Moray for everyone ? Have you checked both compile
versions ?
ABX
Date: 17 Jan 2002 08:55:43
Message: <3c46d7df$2@news.povray.org>
crashes.
compile
> versions ?
yup - moray feeds pov some code with an error, pov dies, moray dies waiting
for pov. kill pov and moray may wake up, but it will not talk to a restarted
pov, so it has to be restarted
parse error can be anything from a missing include to a poorly named texture
(eg 'sphere')
has done that with every version of pov3.5 and moray I have tried
I am thinking perhaps the GUI DLL code would be a good place to start
looking....
PGP Public Key
Date: 17 Jan 2002 09:03:14
Message: <h5md4ukhrsnabmu2qkm2pbs1el2ntv0opj@4ax.com>
On Thu, 17 Jan 2002 13:46:43 -0000, "Rick [Kitty5]" <ric### [at] kitty5com> wrote:
I can't find any note about it on Known Bugs list.
Can you prepare proper report for povray.beta-test (or if it was reported
earlier then refresh it for Known Bugs list coordinator) ?
I feel some persons work with Moray with 3.5 so perhaps there is something with
platform ?
ABX
Date: 17 Jan 2002 13:01:24
Message: <8f3e4ug8j2b1n4s7islqc81codulrr5hnm@4ax.com>
Guys, it's a well known issue between me and the POV-Team that we have
spent some time looking at, but haven't been able to resolve. At this
point, it's not clear whether it's a POV-Ray bug or a Moray bug. While
I tend to think it's a POV-Ray problem, neither the POV-Team nor I
could find the root of the problem (the code does not return from a
SetFocus() call to Windows). I will be devoting more time to it next
week to see if I can find a workaround or fix.
Note that Moray does not crash. It hangs while trying to communicate
for about 5 seconds after which normals processing resumes for a short
while. Then it waits another 5 seconds, etc. This means you can leave
Moray with Alt-F4 or whatever means and save your work. You do need to
kill POV-Ray. The menu item Tools|Reset POV-Ray Comms was actually
meant to detach Moray from POV-Ray, but I think it doesn't work if the
Material Editor has been opened. My current developer version of Moray
can recover with this menu item.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
