I have seen how you can apply soft shadows in povray with spot lights and
omni lights. Somebody can tell me how can I do the same in moray?
Thanks.
Antonio
"Antonio Garrido" <aga### [at] ctv es> escribió en el mensaje
news:3c3cb281@news.povray.org...
> Thanks.
> Antonio
Sorry Antonio, too much work here in Real Life to answer your last post.
I think the soft shadows with spot and point lights can be obtained using
fade_power and fade_distance.
To know how this modifiers work, you can take a look at the documentation
(look at povray docs also).
Good luck
Bye
Txemi Jendrix
tji### [at] euskalnet net
http://www.geocities.com/txemijendrix
Txemi Jendrix <tji### [at] euskalnet net> wrote:
: I think the soft shadows with spot and point lights can be obtained using
: fade_power and fade_distance.
Not really. You need area_light for that.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
just use area lights
PGP Public Key
another way is to use so many lights at *nearly* the same place that the
shadows seem to fade out smoothly. i found out that you will need
between 10 and 20 lights to create a smooth fade. no problem with the
moray duplicate-option!
and rendering seems to be much faster than with area lights.
alex
I can't really believe that ...
especially, if they are at the same position, how can the shadows become
smooth ?
if you distribute them a little bit, you do the same thing, as area_lights
do,
but a_l do more ... They don't need so much light_sources as they support
jitter and adaptive sampling ...
Note: The more lightsources you have, the slower your rendering will be ...
"Somehow what you suggest is like suggesting to add drills \ jan### [at] lzer net
to cars so you can drill for oil when you run out of fuel. \
Sure you could do it, but it might not be the most practical > Jan
solution." [Thorsten Froehlich in p.u.p] / Walzer
I agree that your render will be slower. Also keep in mind that if your forget
to lower the
magnitude for each individual point light, your scene might be a bit brighter
than expected,
whereas an area light only has one magnitude value to worry about.
-Lawrence
> smooth ?
> do,
Alex Wolff <ale### [at] gmx de> wrote:
: and rendering seems to be much faster than with area lights.
This can't be true.
You are probably creating a non-adaptive area light with 100 points and
comparing it with 10 individual point lights.
Create the area_light with the same amount of points as your trick and
use adaptiveness (eg. adaptive 0, adaptive 1 or whatever is the smallest
number which gives a good result). The area_light should render a lot faster.
On 9 Jan 2002 18:40:42 -0500, Warp wrote...
Or you can use lots and lots of point lights or spotlights with
fade_power etc set. I know you can 'cos i've done it when I got bored.
Bye for now,
Jamie.
Jamie Davison <jam### [at] ntlworld com> wrote:
:> Not really. You need area_light for that.
: Or you can use lots and lots of point lights or spotlights with
: fade_power etc set.
But why would you want to do so? area_lights do exactly that, but you
can use adaptive sampling in order to seed up the rendering.
Isn't there a 'soft shadows'-Feature in POV3.5?
If so (I don't know really) this should be supported
in a future version of moray.
Very neccessary!
-C-H-A-R-L-E-S-
> Very neccessary!
use an area light instead or a point light
point lights are just that, all the light comes from an infinitely small
point, you will get perfect hard edged shadows
area lights are essentially a grid of point lights, except you can have the
samples merged - giving you soft shadows (the default settings)
just has a play with only area lights
PGP Public Key
But I dont want to use area lights. I want to get soft edges with
spotlights. I have seen some kind of example for doing it in povray.
Could I use spotlight in moray, send the file to pov ray, re-write de file
modifyng the spolight settings and re-run the render? Thanks.
Antonio.
Example.
light_source {
<20, 30, -15>
color White
spotlight
radius 6
falloff 8
tightness 10
area_light <5, 0, 0>, <0, 0, 5>, 3, 3
adaptive 1
jitter
point_at <-.7, 0, 2>
light_source {
<-20, 30, -3>
color Blue
spotlight
radius 4
falloff 6
tightness 10
adaptive 1
jitter
point_at <-1, 0, 0>
light_source {
<20, 30, -3>
color Red
spotlight
radius 4
falloff 6
tightness 10
adaptive 1
jitter
point_at <1, 0, 0>
Antonio Garrido <aga### [at] ctv es> wrote:
: But I dont want to use area lights. I want to get soft edges with
: spotlights.
Do you mean that Moray doesn't support lights which are spotlights and
area lights at the same time?
I didn't say you waould want to, I was merely correcting your assertion
that you *had* to use area lights.
Bye for now,
Jamie.
"Warp" <war### [at] tag povray org> schrieb im Newsbeitrag
news:3c3effba@news.povray.org...
> : spotlights.
this is of course true for moray ... you can't have both for one
lightsource...
maybe lutz can correct this in his next patch ... but it's been there since
Moray3
