POV-Ray : Newsgroups : moray.win : Problems with Reference'd Objects and local coord's for rotation Server Time
11 Nov 2026 20:58:37 EST (-0500)
  Problems with Reference'd Objects and local coord's for rotation (Message 1 to 2 of 2)
Subject: Problems with Reference'd Objects and local coord's for rotation
Date: 2 Jan 2002 02:43:15
Message: <3c32ba13$1@news.povray.org>
Hello:
  I'm making a torsion bar tank suspension.  I made a 'road wheel' and moved
it into position.  I then use 'duplicate object' and displace the wheels in
Y.
  If I rotate the first wheel, it works fine - it spins around it's center.
  If I rotate any of the other wheels, they spin around the origin?
  I'm having the same problem with the suspension 'arms'.  (a simple cube,
long and thin; the 'axles' won't move so are part of the body.  I made
refences for them, and then moved the local coords to the end of the bar;
thinking that this way it would pivot 'up and down'. This works fine, again
for the first object.  The reference'd objects spin about the origin!
  Any suggestions?  Should I just reset each reference'd objects local
coords?  (there are over 80 of these).
                  == John ==
Subject: Re: Problems with Reference'd Objects and local coord's for rotation
Date: 2 Jan 2002 08:39:37
Message: <3c330d99$1@news.povray.org>
yes ... (at least this is, what I would do next)
Jan Walzer <jan### [at] lzernet>
"John D. Gwinner" <jgw### [at] dazsicom> schrieb im Newsbeitrag news:3c32ba13
