POV-Ray : Newsgroups : moray.win : Background rendering in Pov Server Time
28 Jul 2024 02:31:20 EDT (-0400)
  Background rendering in Pov (Message 1 to 7 of 7)
Subject: Background rendering in Pov
Date: 18 Dec 2001 11:58:56
Message: <3c1f75d0@news.povray.org>
Hello,
I had to replace my faulty hard drive, and so I had to re-install my
programs. Now when I make something in Moray (3.3 with patch), the rendering
in Povray has no background, just a gray and white checkerboard pattern
instead of the background created in Moray. How can I fix this?
Thank you,
Steve Shelby
Subject: Re: Background rendering in Pov
Date: 18 Dec 2001 12:16:53
Message: <3c1f7a05@news.povray.org>
Steve Shelby <ssh### [at] rexnetnet> wrote:
: I had to replace my faulty hard drive, and so I had to re-install my
: programs. Now when I make something in Moray (3.3 with patch), the rendering
: in Povray has no background, just a gray and white checkerboard pattern
: instead of the background created in Moray. How can I fix this?
  What is "the background created in Moray"?
  When you use +ua, then the background uses that checkered background.
Date: 18 Dec 2001 12:29:49
Message: <3c1f7d0d$1@news.povray.org>
Warp,
The background created in Moray is set in Scene/Settings/Background. What is
+ua?
Steve
Warp <war### [at] tagpovrayorg> wrote in message news:3c1f7a05@news.povray.org...
rendering
M()}}
Warp -
Date: 18 Dec 2001 13:07:43
Message: <3c1f85ef@news.povray.org>
: What is +ua?
  Use alpha channel.
Date: 18 Dec 2001 15:03:40
Message: <3c1fa11c@news.povray.org>
OK, where is that supposed to go?
Warp <war### [at] tagpovrayorg> wrote in message news:3c1f85ef@news.povray.org...
> : What is +ua?
>   Use alpha channel.
x]
Warp -
Date: 18 Dec 2001 19:55:43
Message: <3c1fe58f@news.povray.org>
news:3c1fa11c@news.povray.org...
I think it's in Moray.ini file, in Moray's main directory.
You have to search for the item: "Output_Alpha=On" and turn it to
"Output_Alpha=Off".
Save the file and start Moray.
Render again.
Hope this helps
Txemi Jendrix
tji### [at] euskalnetnet
http://www.geocities.com/txemijendrix
Date: 18 Dec 2001 20:11:52
Message: <3c1fe958@news.povray.org>
That worked! THANK YOU.
Steve
Txemi Jendrix <tji### [at] euskalnetnet> wrote in message
news:3c1fe58f@news.povray.org...
> "Output_Alpha=Off".
> Render again.
> Hope this helps
> Txemi Jendrix
