![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hello,
I had to replace my faulty hard drive, and so I had to re-install my
programs. Now when I make something in Moray (3.3 with patch), the rendering
in Povray has no background, just a gray and white checkerboard pattern
instead of the background created in Moray. How can I fix this?
Thank you,
Steve Shelby
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Steve Shelby <ssh### [at] rexnet net> wrote:
: I had to replace my faulty hard drive, and so I had to re-install my
: programs. Now when I make something in Moray (3.3 with patch), the rendering
: in Povray has no background, just a gray and white checkerboard pattern
: instead of the background created in Moray. How can I fix this?
What is "the background created in Moray"?
When you use +ua, then the background uses that checkered background.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Warp,
The background created in Moray is set in Scene/Settings/Background. What is
+ua?
Steve
Warp <war### [at] tag povray org> wrote in message news:3c1f7a05@news.povray.org...
rendering
M()}}
Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
: What is +ua?
Use alpha channel.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
OK, where is that supposed to go?
Warp <war### [at] tag povray org> wrote in message news:3c1f85ef@news.povray.org...
> : What is +ua?
> Use alpha channel.
x]
Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
news:3c1fa11c@news.povray.org...
I think it's in Moray.ini file, in Moray's main directory.
You have to search for the item: "Output_Alpha=On" and turn it to
"Output_Alpha=Off".
Save the file and start Moray.
Render again.
Hope this helps
Txemi Jendrix
tji### [at] euskalnet net
http://www.geocities.com/txemijendrix
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That worked! THANK YOU.
Steve
Txemi Jendrix <tji### [at] euskalnet net> wrote in message
news:3c1fe58f@news.povray.org...
> "Output_Alpha=Off".
> Render again.
> Hope this helps
> Txemi Jendrix
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
