POV-Ray : Newsgroups : moray.win : default global settings change Server Time
17 Jan 2026 05:32:27 EST (-0500)
  default global settings change (Message 1 to 3 of 3)
Subject: default global settings change
Date: 9 Sep 2001 15:50:18
Message: <3b9bc7fa@news.povray.org>
is there a way to change the default global settings that moray writes in
every moray file.
global_settings {
  adc_bailout 0.003922
  ambient_light <1.0,1.0,1.0>
  assumed_gamma 1.9
  hf_gray_16 off
  irid_wavelength <0.247059,0.176471,0.137255>
  max_intersections 64
  max_trace_level 10
  number_of_waves 10
  radiosity {
    brightness       3.3
    count            100
    distance_maximum 0.0
    error_bound      0.4
    gray_threshold   0.5
    low_error_factor 0.8
    minimum_reuse    0.015
    nearest_count    6
    recursion_limit  1
i need to change the adc_bailout
and max_trace_level ..
i can hard code it.. but it would be a little easier if i could change it
through moray.
or in the moray.ini (or where ever it is)
thankyou darrell miller
Subject: Re: default global settings change
Date: 10 Sep 2001 16:33:54
Message: <au8qpt8s8buhtgga044cucjbl16jr5lh1h@4ax.com>
Hi Darrell Miller, you recently wrote in moray.win:
> every moray file.
Scene|Settings|Global Settings
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 10 Sep 2001 23:50:41
Message: <3b9d8a11@news.povray.org>
wow, i really am a retard..
thankyou for making it so easy.
-darrell miller
"Lutz Kretzschmar" <lut### [at] stmuccom> wrote in message
news:au8qpt8s8buhtgga044cucjbl16jr5lh1h@4ax.com...
in
> > every moray file.
> - Lutz
