![](/i/fill.gif) |
is there a way to change the default global settings that moray writes in
every moray file.
global_settings {
adc_bailout 0.003922
ambient_light <1.0,1.0,1.0>
assumed_gamma 1.9
hf_gray_16 off
irid_wavelength <0.247059,0.176471,0.137255>
max_intersections 64
max_trace_level 10
number_of_waves 10
radiosity {
brightness 3.3
count 100
distance_maximum 0.0
error_bound 0.4
gray_threshold 0.5
low_error_factor 0.8
minimum_reuse 0.015
nearest_count 6
recursion_limit 1
i need to change the adc_bailout
and max_trace_level ..
i can hard code it.. but it would be a little easier if i could change it
through moray.
or in the moray.ini (or where ever it is)
thankyou darrell miller
![](/i/fill.gif) |
