![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Is it possible to export a Moray scene to a POV file?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Sun, 1 Jul 2001 11:56:10 -0700, Jason Jong wrote...
Yes.
Or were you after more info than that?
Press Ctrl-F9, and the corresponding .pov and .inc files will be exported
into your standard location (usually /moray for windows/povscn)
Bye for now,
Jamie.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It's not only possible, that's the way moray communicates with povray.
Every file you render, you can find a pov-file in the povscn subfolder.
If you want to export a file without rendering it, press ctrl-f9. Then
you can find it in the povscn folder as well (if i recall right)
Arne Kleinophorst
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Arne Kleinophorst" <kle### [at] debitel net> wrote in message
news:3B3F8BD5.DF690895@debitel.net...
Yes, that's correct. The full path (assuming you're using the default
setup) is:
C:\Program Files\Moray For Windows\PovScn\[filename].pov
There is also an .INC file in the same directory with all your texture
information.
-Ian
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Is there a way to make it left handed?
"Ian Burgmyer" <the### [at] hotmail com> wrote in message
news:3b3fe8ae$1@news.povray.org...
> setup) is:
> information.
> -Ian
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi Digger Mole, you recently wrote in moray.win:
No.
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> No.
can you not just do a numerical conversion at the point of export?
PGP Public Key
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > No.
No.
Ken Tyler
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Drat
That's all I have to say...
unless you took out the part that says to make right handed, and then put a
union around it and rotated or something like that
"Ken" <tyl### [at] pacbell net> wrote in message
news:3BC857A7.5F138260@pacbell.net...
> > > No.
> No.
> Ken Tyler
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
