POV-Ray : Newsgroups : moray.win : Textures proxies Server Time
11 Nov 2026 21:22:49 EST (-0500)
  Textures proxies (Message 1 to 4 of 4)
Subject: Textures proxies
Date: 24 Jun 2001 20:43:57
Message: <3b36894d@news.povray.org>
I have a question about textures proxies in Moray 3.3:
When I do a material with an image map, for example, and I apply
transformations (scale, rotate, translate) to it consecutively, each time I
come back to the Moray general interface I don't get from it the new
placement of the material in any view. To obtain it I have tried: refresh
window (I thought this would be the most logical item), maximize / minimize,
and so on.
Finally I have found that there are only two ways to get a good result (to
see the new location and shape of the material) that are:
1.- Render the scene.
2.- Go to View Menu and deactivate "show all material proxies" and repeat
the operation to activate again.
Is this a right behave (I don't think so)? I'm missing something?
Answers (Lutz)?
Txemi Jendrix
tji### [at] euskalnetnet
Subject: Re: Textures proxies
Date: 24 Jun 2001 21:42:48
Message: <3b369718@news.povray.org>
> Answers (Lutz)?
I think you have found a slight oversight, never really noticed myself
(until you mentioned grr) as I usually position the material proxies via the
modeller viewports
PGP Public Key
Date: 25 Jun 2001 04:58:45
Message: <k0vdjt4r6o7p0l9r95cq2f6dm04jt0df7g@4ax.com>
Hi Txemi Jendrix, you recently wrote in moray.win:
I assume you mean that you are adding or changing a transformation
node in the Material Editor? Then you are right, there is a bug there.
In OpenGL mode, a simple Refresh is missing (Ctrl-R, or pan). In Moray
mode a Refresh isn't enough, but reselecting the texture (Shift-Drag)
will update the proxy.
No, it's a bug.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 26 Jun 2001 17:02:21
Message: <3b38f85d@news.povray.org>
"Lutz Kretzschmar" <lut### [at] stmuccom> escribió en el mensaje
news:k0vdjt4r6o7p0l9r95cq2f6dm04jt0df7g@4ax.com...
> No, it's a bug.
That's what I thought.
Txemi Jendrix
