POV-Ray : Newsgroups : moray.win : my spaceship anim test Server Time
11 Nov 2026 21:22:56 EST (-0500)
  my spaceship anim test (Message 1 to 15 of 15)
Subject: my spaceship anim test
Date: 12 Jun 2001 10:24:18
Message: <3b262612@news.povray.org>
Thanks for the responses.  I uninstalled everything, and started again, same
same.
My apologies for the pic, but the attached image appears everytime I start
Moray, been so long I don't remember if it's normal.
I seem to recall making anims with these in win2k months ago.  so it may be
my mdl file.  I posted in Moray.binaries under the same subject, the mdl
file that I'm using.
It uses Moray 3.3, Pov 3.1G, galaxy plugin, anim plugin, and spray
plugin.there are 60 frames (12 fps for 5 sec) and 2 key frames.  I
positioned the ship and the spray object off camera for first frame, and
moved them to center for final frame.  Whn I go to render in POV, first
frame renders, and then Moray crashes.
TIA
DeanM
Download 'morayscreen.gif' (11 KB)
Preview of image 'morayscreen.gif'
Subject: Re: my spaceship anim test
Date: 12 Jun 2001 14:44:53
Message: <3b266325@news.povray.org>
Hi, it's me again...
I just ran another test, this time I used just the spaceship model and a
galaxy object. I set the spaceship to x=-10, and on frame 15 x =0, just
enough to push it in to camera view, and it crashed again.  however previous
to that made a sphere move between 3 points forming a triangle, and it had
no problem.  maybe my spaceship isn't anim friendly
Date: 12 Jun 2001 14:49:52
Message: <3b266450@news.povray.org>
I've also ruled out the galaxy plugin as a culprit, not that I thought it
was, just stripping down.  I'm running my animtest of the sphere moving
around 3 points, now with a galaxy backdrop
Date: 12 Jun 2001 15:08:09
Message: <3b266899@news.povray.org>
OK maybe a slight oddity.  I did a save object, and merge object, to get the
spaceship out of the rest of the logo. just the space ship, and the camera,
and I have hints of light at points of my model, with no lights in the
scene.  behind the nose cone, and at the engine exhaust port. Fuselage is a
hollow rotational sweep, and if I look dead into the exhaust it's dark, but
at an angle it looks like the interior of my sweep is lit.
Hellllllllllllllllllllp please.
Date: 12 Jun 2001 16:17:09
Message: <o3ucitc5gomhbdv9nfhraffsvvmpmhl458@4ax.com>
Hi Dean MacIsaac Jr., you recently wrote in moray.win:
Hmmm. Do you dismiss this dialog box with OK? If so, it should not
come back next time. What that would mean is that Moray can't
configure POV-Ray properly. And that might be the reason things aren't
working smoothly....
Do you have multiple POV-Ray versions installed? You may want to
describe the paths and installations of POV-Ray that you have....
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 13 Jun 2001 09:51:30
Message: <3b276fe2$1@news.povray.org>
Dean,
For what it's worth, I opended your .mdl file in moray, and when I tried to
render it, PovRay would not render, siting an error opening "texture2.bmp"
Steve Shelby
Dean MacIsaac Jr. <dma### [at] starabiliascom> wrote in message
news:3b262612@news.povray.org...
same
> same.
be
> TIA
> DeanM
Date: 13 Jun 2001 09:55:50
Message: <3B277170.C60831BC@debitel.net>
sshelby schrieb:
> Dean,
> Steve Shelby
i got that error as well but thats not the point. just take any bitmap
instead. But when trying to render this animation my computer took a
total timeout ( & told me to go to bed at 1.00 am :) ) There seems to be
something really crazy with this file, but i've not been able so far to
find out what.
so long  Arne
Date: 13 Jun 2001 10:00:35
Message: <3b277203$1@news.povray.org>
sorry my fault, I'm about to post a new item in m.b I'll make a zip witht
the textures.
Date: 13 Jun 2001 10:09:36
Message: <3b277420@news.povray.org>
first time I started moray today, the same window opened but each time after
that it did not.  However I just opened Moray by doubleclicking on my
spaceship.mdl, and it reappeared.  Moray Com. DLL installed NO.
I firmly believe my model is at fault.  I made an animation of a ball with
the galaxy background, and it animated fine.
I'm going to post images, and a zip in m.bin.  this goes with my previous
self response with odd things going on in my model.
I appreciate everyones help, turns out it is noones software, (wasn't sure
that it was to begin with), my model is just very wierd.
Thanks again,
DeanM
Date: 13 Jun 2001 11:54:29
Message: <3B278D40.A588BF1E@debitel.net>
Hmm, but the animation is rendering without a prob if you throw out the
Galaxyobject.
just noticed by Arne
Date: 13 Jun 2001 13:06:55
Message: <3b279daf$1@news.povray.org>
Galaxyobject.
NO...  I created a new anim just a sphere moving around a triangle then
slowly added pieces to it, like the galaxy, and it worked everytime.  only
proving the software was working, and the issue was in my spaceship scene,
which does not animate...
if you go to moray.binaries, I posted a zip with 2 pics, very odd, no lights
in scene at all yet light is emiting from inside my spaceship...
hmmmmmm
Date: 13 Jun 2001 14:53:43
Message: <MPG.1591c64e31f7f5a5989947@news.povray.org>
> > Steve Shelby
> find out what.
I had no problems at all opening it and rendering it with the camera in a
variety of positions, and adding and removing light sources...
Maybe the good old fashioned reinstall of Moray and its plugins might
help.  I know that it sorted out some problems I was having with the
LensFX plugin.
Bye for now,
     Jamie.
Date: 13 Jun 2001 19:47:18
Message: <3B27FC11.F426CAC8@debitel.net>
> Galaxyobject.
 Hmmm, the only binary i can find within moroay.binaries with bitmaps
included is the one with the texture2.bmp & this mdl-file is rendering
quite o.k.! IF you throw out the galaxy object. Which in my opinion
doesn't need to mean that the galaxy object isn't working in animations
but means that it's not working in that one. Which isn't really a help,
I guess.
When working with the anim-plugin I tried to stick just to the basic
moray objects just to make sure it's working. In the plugin v0.21?
readme, i guess, there was something vaguely stated about using other
plugins for using other pluginsbut i guess thats untested & unconfirmed.
I'd be really happy to see this feature implemented, but if i understand
it right it requires some changes within the moray-code. So i'm not
sure, whether this whole thing is supposed to work anyway.
so far
Arne
Date: 14 Jun 2001 07:17:07
Message: <ch6hitg3s882udfeffd8e3so7ddlq203da@4ax.com>
> that it did not.
Usually, it should open once and once only, unless you uncheck
something or click on Cancel.
It shouldn't make a difference how Moray is started....
You mean POV-Ray does not show it as loaded? Can you start POV-Ray
from within Moray (exit both Moray and POV-Ray, start Moray, press
F9)? If yes, then go to the POV-Ray GUI-Extensions Menu. There should
be a 'Moray Communications DLL' entry.
If you cannot start POV-Ray or if you meant that the menu entry is not
present in POV-Ray, then for some reason Moray is not able to
configure POV-Ray correctly for use with Moray. In this case you will
have to go to the INI directory of where POV-Ray is installed
(probably C:\Program Files\POV-Ray For Windows\INI) and edit
PVENGINE.INI. Search for a section that starts like this:
 [GUIExtensions]
 UseExtensions=1
Make sure there is a line (or add it if it isn't) like this:
 ExtDll15=C:\Program Files\Moray For Windows\MorayCtrl.DLL
You need to make sure that there is no other ExtDll15 in that section,
otherwise increase the 15 until you get a number that is not present.
Also make sure that MorayCtrl.dll is in that section once only. And
obviously you might need to change the path to point to where
MorayCtrl.dll really is located (Moray installation directory).
Then exit both POV-Ray and Moray and start POV-Ray only. Check the
Message pane, it should say something like this:
GUI Extension 'Moray Communcations DLL' loaded from 'MorayCtrl.DLL'
  Report any problems to blabla....
..and the  GUI Extension menu item should now show Moray
Communications DLL. If the above message does not appear, please let
me know what does appear in the message pane.
I doubt it. Moray should not allow you to construct a model that
causes a problem, so I really would like to see what's up. I will
check the files in moray.binaries.
- Lutz
Date: 14 Jun 2001 12:47:52
Message: <3B28EB3E.913132C8@totalise.co.uk>
I just made the bitmap a standard solid color (i.e. deleted the bitmap)
and the animation ran fine.
Keith
Arne Kleinophorst wrote:
> sshelby schrieb:
> > Dean,
> > Steve Shelby
> find out what.
> so long  Arne
