POV-Ray : Newsgroups : moray.win : leaves with tree plugin Server Time
11 Nov 2026 21:22:50 EST (-0500)
  leaves with tree plugin (Message 1 to 3 of 3)
Subject: leaves with tree plugin
Date: 21 May 2001 23:32:43
Message: <3b09dddb$1@news.povray.org>
hi, i've been messing with the tree plugin GTTree.. it works great .. only
problem is that i cant see how to make more leaves. i've messed with all the
settings with no luck, i'm sure its easy.. but all i seem to get is a tree
with 10 or 12 leaves.. i need a tree with 100's of leaves..
any suggestions?
thanks
darrell miller
dar### [at] earthlinknet
Subject: Re: leaves with tree plugin
Date: 22 May 2001 12:13:42
Message: <3B0A909F.64CA8A57@debitel.net>
> any suggestions?
> thanks
> darrell miller
most important is, that you push up the leaf probability. if you want a
really filled tree set it to 1.
second is the leaf level, it sets up at what level leaves start. so this
must not be larger than the main tree level, otherways no leaves.
hope this helps
Arne
Subject: example in moray.binaries
Date: 22 May 2001 12:37:30
Message: <3B0A9635.6B284687@debitel.net>
> any suggestions?
> thanks
> darrell miller
see file & pic in moray.binaries
greets
Arne
