POV-Ray : Newsgroups : moray.win : Textobject problem Server Time
11 Nov 2026 21:22:57 EST (-0500)
  Textobject problem (Message 1 to 16 of 16)
Subject: Textobject problem
Date: 27 Apr 2001 12:21:37
Message: <3ae99c91@news.povray.org>
Hi @ all,
i´m very new at rendering and all this, so please help me.
I use moray 3..3 to get some nice logos for my coverart.
i tried to use a special font (frozen dog treats) and moray
showed it as
exspected, but as i rendered the whole thing some of the
letters aren´t shown correctly.
they were replaced by other characters, that not present in
this special font.
what did i wrong ?
does this appear to someone else ?
is this a moray or povray problem ?
or even a windows problem ?
thanks
hkn
Subject: Re: Textobject problem
Date: 27 Apr 2001 14:36:25
Message: <3AE9BC28.55580959@ucdavis.edu>
which version of povray are you using?  IIRC, pov 3.1 doesn't handle
fonts as well as megapov does.  i could be wrong though.  you can render
to megapov by putting the megapov exe in the same place as the pov exe,
changing the name of the pov exe to something else, and the name of
megapov to pov's original name.  that way all programs that call pov can
find it easily.
Hakan Kocaman wrote:
> Hi @ all,
> iīm very new at rendering and all this, so please help me.
> showed it as
> letters arenīt shown correctly.
> this special font.
> what did i wrong ?
> thanks
> hkn
Date: 27 Apr 2001 15:40:47
Message: <MPG.1553d46c239c2d4e9898ee@news.povray.org>
On Fri, 27 Apr 2001 11:36:24 -0700, Ryan Constantine wrote...
> find it easily.
Or you can use MegaPOV far more easily by pressing alt-F9, and changing
the POV-ray executable to the megapov executabe of your choice without
having to go through all the hassle of copying and renaming files...
Bye for now,
     Jamie.
Date: 27 Apr 2001 17:29:38
Message: <3ae9e4c2@news.povray.org>
"Jamie Davison" <jam### [at] ntlworldcom> schrieb im
Newsbeitrag
news:MPG.1553d46c239c2d4e9898ee@news.povray.org...
wrote...
doesn't handle
you can render
as the pov exe,
the name of
that call pov can
> > find it easily.
and changing
choice without
renaming files...
> Bye for now,
>      Jamie.
Thanks to you two.
I´m using povray 3.1g and moray 3.3.
I´ll try megapov, good mention thanks
bye
hkn
Date: 28 Apr 2001 06:09:12
Message: <vh5letspu0pjenfugrlkqbpaf0hfjtqdmh@4ax.com>
Hi Hakan Kocaman, you recently wrote in moray.win:
> showed it as > exspected, but as i rendered the whole thing some of the
POV-Ray may have trouble with the font, especially if the characters
you are using are above 128 ASCII. If you like, you can send me the
font file and the MDL file and I can take a look.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 28 Apr 2001 15:39:52
Message: <3AEB1D60.79634B04@yahoo.com>
the reason i prefer renaming is because other programs that use pov
don't have the dialog like moray does.  for example, texture view looks
only for pvengine.exe.  so if you were to try to render a megapov
texture it wouldn't work.  so to be safe, i do the renaming game. :)
> > find it easily.
> Bye for now,
>      Jamie.
Date: 28 Apr 2001 18:47:26
Message: <MPG.155558dfe5cf4e079898f3@news.povray.org>
On Sat, 28 Apr 2001 12:43:28 -0700, Ryan Constantine wrote...
Whatever works for you, but the only real POV application I use is Moray,
so I find the alt-F9 trick works well for me.
(or, what I really think)
Masochist...
<grin>
Bye for now,
     Jamie.
Date: 29 Apr 2001 16:30:50
Message: <3aec79fa@news.povray.org>
Newsbeitrag
news:MPG.155558dfe5cf4e079898f3@news.povray.org...
wrote...
that use pov
texture view looks
a megapov
renaming game. :)
I use is Moray,
Thanks for your help :)
I tried the "renaiming"-method and it worked fine,
is this also an easy way to upgrade to other enginges ? nice
Unfortunately it changed nothing, but maybe it´s a problem
by the font
are their maybe special 3d-fonts to use with moray, i
searched at povray, but found nothing.
maybe i try another way
by hkn
> Masochist...
> <grin>
> Bye for now,
>      Jamie.
Date: 29 Apr 2001 16:39:57
Message: <3aec7c1d@news.povray.org>
"Lutz Kretzschmar" <lut### [at] stmuccom> schrieb im Newsbeitrag
news:vh5letspu0pjenfugrlkqbpaf0hfjtqdmh@4ax.com...
moray
thing some of the
characters
send me the
Thanks,
sure i´ll do this, but i´m unsure wether this font is
window-integrated.
It´s named "Frozen Dog Treats" and it´s on it´s way to you
Maybe i just should use another font, it´s just for fun but
is art really fun :~)
bye
HKN
Date: 29 Apr 2001 16:41:58
Message: <MPG.15568d06516261179898f8@news.povray.org>
It's a way to use other, patched and third party compiled versions of
POV, but it wouldn't allow you to use another renderer which isn't 100%
POV code compliant.
> by the font
> by hkn
If you want to post the .mdl files and the offending font fil in
moray.binaries, I'll have a look at it and see if I can spot anything
obviously wrong with it.
Bye for now,
     Jamie.
Date: 29 Apr 2001 17:16:34
Message: <3aec84b2@news.povray.org>
moray
thing some of the
characters
send me the
> - Lutz
I tried to ad it to email, but this won´t work.
Do anyone know aprogram where i can export
fontfiles from windows 98 ?
i think i got to check my windows-knowlegde :~)
bye
hkn
Date: 30 Apr 2001 13:00:01
Message: <3AED9A52.6D152988@debitel.net>
> I tried to ad it to email, but this wonīt work.
> bye
> hkn
You can't do it from the /windows/font folder. So you must copy it out
of there first. The only thing to do that seems to be via command-line
mode.
So you must open a ms-dos-window, locate the font (read: it's Dos-name)
in the fonts folder and copy it somewhere else, then you can add it to a
mail.
Hope this helps
Arne Kleinophorst
Date: 30 Apr 2001 15:05:42
Message: <3aedb786@news.povray.org>
thanx , but i found it on the web and mailed this one to
Lutz
bye for now
hkn
"Arne Kleinophorst" <kle### [at] debitelnet> schrieb im
Newsbeitrag news:3AED9A52.6D152988@debitel.net...
> > bye
> > hkn
copy it out
command-line
> mode.
it's Dos-name)
can add it to a
> mail.
> Hope this helps
> Arne Kleinophorst
Date: 3 May 2001 06:36:13
Message: <3af1349d@news.povray.org>
I have the same problem with Greek characters. When I use a TT font
(unicode) and I use greek characters, although the text box in the side bar
shows the text in greek the text object shows other (non-greek) characters.
Since I want a text object with greek characters is there any solution?
"Hakan Kocaman" <Hak### [at] t-onlinede> wrote in message
news:3aedb786@news.povray.org...
> Lutz
> bye for now
> hkn
> > > bye
> > > hkn
> copy it out
> command-line
> > mode.
> it's Dos-name)
> can add it to a
> > mail.
> > Hope this helps
> > Arne Kleinophorst
Date: 3 May 2001 15:06:26
Message: <MPG.155bbca7e14b9f60989901@news.povray.org>
On Thu, 3 May 2001 13:39:28 +0300, SWIFT ETEBA wrote...
Basically, it's a problem with POV 3.1g.  (at least as far as i
understand the matter)
Try using megapov as your renderer instead and it may fix things.  If
not, then I don't really have any ideas, as I try to avoid using text
objects if at all possible due to their dog slow rendering speed.
I think the problem with fonts is due to be fixed in the upcoming POV
3.5, but until that is released, your best bet is probably to try using
MegaPOV.  if you've not got a copy yet, it can be found at
http://nathan.kopp.com
Bye for now,
     Jamie.
Date: 4 May 2001 14:35:44
Message: <sit5ftov9cfkrt67fqvtbu1evtdd05ukcg@4ax.com>
Hi Jamie Davison, you recently wrote in moray.win:
Yes, it is.
Yes, it does. MegaPOV has no problems with the font.
- Lutz
