Hi there,
I'm doing a povray scene and a friend of mine has started building
some objects for my scene, but we realized that we couldn't output some
povray code from moray... is there a way to make a file.pov out of a
moray work project?
Thanks
Xilo
Dedicated to audio/visual and interactive artwork.
Author of The Primary Colors of CSound:
http://www.geocities.com/simonlemieux/PCCS/index.html
Xilo Musimene <xil### [at] hotpop com> escribió en el mensaje de noticias
3EA### [at] hotpop com...>
> moray work project?
In the menu bar -> Render -> Export.
Also when you render a scene from Moray,
the pov files are created: *.ini, *.pov, *.inc
where * is the name of your moray scene.
If you need to change the coordinates (in Moray z is up,
in POVRay y is up), you'll need to do this to your objects
(this must go before any other transformation):
Moray -> Pov:
scale <1,1,-1>
rotate x*90
Pov -> Moray
scale <1,1,-1>
rotate -x*90
Hope this helps.
Txemi Jendrix
http://www.txemijendrix.com
> Moray -> Pov:
> scale <1,1,-1>
> rotate x*90
> Pov -> Moray
> scale <1,1,-1>
> rotate -x*90
> Hope this helps.
Well, unfortunately I'm not working myself with moray (only my friend
is) but I forwarded this post to him and I think it will answer all his
questions. I believe it should be perfect!
Thanks a lot!
Xilo
