Have a converted 3ds file.
Turned off the following two menu items in POV-Ray:
Editor|Auto-Load Error File
Editor|Auto-Show Parse Messages
Have the directory of the udo and inc files in the ini file.
Have script I/O set to no restrictions.
WHY THE EFF IS IT SAYING IT CAN'T LOAD THE DAMN THINGS?
Tim Cook
Version: 3.12
3CF### [at] bellsouthnet...
I have had similar problems. The way I solved them was putting the .inc
files in Moray's Povscn directory.
Hope this helps
Txemi Jendrix
tji### [at] euskalnetnet
http://www.geocities.com/txemijendrix
> Hope this helps
Still doesn't work...ah, I see, the *_p.inc file is referencing a
*_o.inc file which DOESN'T EXIST. Sloppy coding if ya ask me...if
I tell 3dwin not to export the materials, it should at least generate
a dummy *_o.inc file so pov doesn't 'shit a brick', as it were.
Tim Cook
Version: 3.12
Hmm, it did export the materials...so what the heck is the *_o.inc file
for, and why doesn't 3dwin generate it?
Tim Cook
Version: 3.12
Hmm, after checking every option box in 3dwin, I finally get the *_o.inc
file which is a buttload of vertices...why didn't it generate it before?
All I wanted was the mesh and its textures, had those options checked,
as well as global settings, but it didn't make the *_o.inc file...
Tim Cook
Version: 3.12
And now it works. *scratches head*
Tim Cook
Version: 3.12
in povray one of the menus allows you to disable IO restrictions.
PGP Public Key
Didn't he just say that he has it set to no restrictions?
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
Indeedy I did. BTW, something strange about PoseRay 2.something
...it creates a material called 'default' which wreaks havoc with
POV, since POV doesn't like "#define default=material..."
That and the (unrelated) fact that media's a pain in the hindquarters
to get to do what you want it to...
Tim Cook
Version: 3.12
